996 Forum 1999-2005
Can't open my engine lid.
Old 02-26-2011, 02:55 AM
Shanbin
Cruisin'
Shanbin's Avatar
Default Can't open my engine lid.
I haven't drive my car for almost 2 month. Now the battery is totally dead...LOL.
I tried to open the engine lid and jump the car. However, after I followed the insturction by the mannel. I can open my luggage lid, but not my engine!
I use the battery of my audi to do that..
Who can help me ?
this link is the same as what I do.
http://perryandcoblog.com/2009/11/17...hood-solution/
Old 02-26-2011, 03:31 AM
Pac996
Pac996's Avatar
Right, the battery is in the front in the middle under the plastic cover just past the water tight seal under the windshield.
Old 02-26-2011, 11:15 AM
Sneaky Pete
Sneaky Pete's Avatar
So pull the plastic cover off the battery and jump it. To be clear the battery is in the front trunk and not in the rear by the engine. Good Luck!
Old 02-26-2011, 11:47 AM
Ed 40Jahre
Ed 40Jahre's Avatar
You might have to do as I did: Jump the car with another car using the system explained in your manual.
i.e. in the fuse box pull out the jumper fuse and connect the positive to it, place the neg. (clamp it to the body under the car) in the jack hole / pad. This is a better bond for the grounding than the door latch as suggested in the manual.
This should allow you open the front hood and replace the battery....I found Pep Boys had the correct battery for $99.00 best price as compared to Sears ($139.00) and Firestone ($198.00)...
Ed
Old 02-26-2011, 11:52 AM
Sneaky Pete
^^^He has the front trunk open but sounds like he doesn't know where the battery is.
Old 02-26-2011, 12:01 PM
Ed 40Jahre
Ed 40Jahre's Avatar
Re-read, stand corrected...
thanks
ed
Old 02-26-2011, 12:05 PM
Ed 40Jahre
Ed 40Jahre's Avatar
Pete,
maybe you can answer a question, can't seem to post a picture on my correspondence. URL?
Not to savvy tec wise.
Old 02-26-2011, 12:48 PM
Sneaky Pete
Originally Posted by Ed 40Jahre
Pete,
When you reply click on the advanced button and than click on the paper clip symbol.That will open a window where you can browse for the file type / image you want to upload or attach. If you are doing that and it does not allow you maybe the file size might be the issue. Than you will have compress or reduce the file size before you can upload it. Hope that helps.
Old 02-26-2011, 12:54 PM
Ed 40Jahre
Ed 40Jahre's Avatar
Giving it a try.
Thanks Pete
Old 02-26-2011, 01:08 PM
Sneaky Pete
We have a pic!
Old 02-26-2011, 01:17 PM
Shanbin
Cruisin'
Shanbin's Avatar
Hey, I could find my batter..However, i thought I should jump the car using the two connected pointed near the engine. Could I just jump the battery?
Old 02-26-2011, 01:20 PM
Shanbin
Cruisin'
Shanbin's Avatar
Giving it a try.
Thanks Pete
Thanks man .My car looks exactly like your pic!
Old 02-26-2011, 01:26 PM
Sneaky Pete
I would. You can connect to the + pole and connect to the u-bracket for the hood latch for the -. The reason you don't go direct to both poles on the battery is for fear of blowing the battery up.....I have to admit that I have done that several times throughout the years and have not had an issue.
Old 02-26-2011, 01:34 PM
Shanbin
Cruisin'
Shanbin's Avatar
Giving it a try.
Thanks Pete
I'll try that..
The problem is my cable is not long enough. I am going to jump the car now. Should I just pull out of my battery and disconnect with my porshce and then jump it? Or still leave it in my car and jump it?
The idea way is to connect those two points in my rear lib. However can't open it..lol
Old 02-26-2011, 01:43 PM
Sneaky Pete
Huh? Leave the battery in the Porsche. Take another car and get it close to the Porsche battery. Connect the JUMPER cables from the Porsche to the donor car. Let the donor car run for 10 minutes while connected to the Porsche.......than start the Porsche and disconnect the cables in reverse of the way you put them on and don't let them touch each other.
Quick Reply: Can't open my engine lid.
