996 Forum 1999-2005
Not sure that my PSM is working
Old 02-17-2011, 12:32 PM
Dharn55
Dharn55's Avatar
I don't think a standard OBD reader is going to show a PSM fault. The default on the PSM is on, the button turn it off and both the switch light and the light on the dash come on. It could be a bad switch. loose wire, etc. etc.
Old 02-17-2011, 08:08 PM
mglobe
The Penguin King
mglobe's Avatar
Checking fuses is the easiest thing you could do. I would start there.
Old 02-19-2011, 03:43 PM
BuddyK
BuddyK's Avatar
Push the other side of the oval button. Maybe you are pushing the wrong side of the button? Just a guess.
Light will glow and PSM OFF orange light on the dash will also be glowing.
With PSM off you should easily be able to break the rear end free and do a donut on an icy or wet surface.
With PSM on, you'll feel it. PSM takes some of the fun out of driving, but is very very good for safety. I leave it on unless I want to snow drift, or autocross, or slide a corner for fun.
Old 02-19-2011, 10:52 PM
Toomanycars
Toomanycars's Avatar
I've tried both sides of the switch. And I wasn't aware I could do donuts in a C4s
Old 02-19-2011, 11:57 PM
redridge
redridge's Avatar
one of the few awd that can do donuts because of the viscous coupling.
[vid]http://www.youtube.com/watch?v=_Gh38VcqOsU[/vid]
Old 02-20-2011, 04:49 PM
Toomanycars
Well I checked the fuses and all were good. I removed the switch and it appears to be working with a multimeter connected but I'm not sure which connections are supposed to get voltage on them. Next time I'm at the dealership I'll have them check it out.
Old 02-20-2011, 10:41 PM
Toomanycars
Ok so PSM works. It actually rained for once today and I went out and got on it and the dash light started flashing. Just can't turn it off I guess.
Old 02-20-2011, 11:05 PM
Sneaky Pete
Sneaky Pete's Avatar
Guess you weren't driving hard after all Still wonder why the switch doesn't lite up...
Quick Reply: Not sure that my PSM is working
