996 Forum 1999-2005
OIL OIL OIL !!!
Old 12-10-2010, 03:12 PM
100plus
100plus's Avatar
wow ... a whole load to read up on ... From flipping through, looks like its best to stick to mobile 1 0-40?? Summary would be great ... (:
Old 12-10-2010, 03:16 PM
Macster
Macster's Avatar
Originally Posted by 100plus
just one question, what viscosity do you guys recommend for 31 degrees celsius climate? Downsides to running 10-40 or even 15-50?
31C? Man, that's cold... Last summer coming across AZ into CA I drove many many miles through 47C heat (118F) in my 03 Turbo.
For several oil changes now I've been using Castrol Syntec 5w-50.
And I change this every 5K miles.
Sincerely,
Macster.
Old 12-10-2010, 03:18 PM
soverystout
soverystout's Avatar
Just stop. The oils we may use here in North America may not even be available to you in Singapore. 0W-40 or 5w-40 make up the entire recommended oil list provided by Porsche.
Mobil 1 and Castrol are fine and may be available in your market.
http://members.rennlist.org/jandreas...ved_A40_En.pdf
Old 12-10-2010, 03:21 PM
frisbee91
frisbee91's Avatar
Okay,
Serious question. Assuming you are using a big-brand synthetic (Mobil 1 xW40, Syntec xW40), WHERE do you get it? Some of my local auto parts chains seem to have limited selection of these less common viscosity blends.
Old 12-10-2010, 03:23 PM
ivangene
Parts Specialist
ivangene's Avatar
Just stop? Hey this is a great distraction for that "other thread"
how ofter should you change the OIL too....
and did you hear about the Blonde who asked the parts guy for a new 710 cap, said her motor used to have now, now its gone?
Old 12-10-2010, 03:24 PM
ivangene
Parts Specialist
ivangene's Avatar
Originally Posted by frisbee91
Okay,
buy mine on-line
soverystout
Okay,
every pepboys in our area (Delaware) has plenty of Mobil 0w -40 and Castrol Syntec 5W-40. Where are you shopping?
Old 12-10-2010, 03:31 PM
beentherebaby
beentherebaby's Avatar
Oil is a religion for some folks and in many cases completely devoid of reason or good judgment.
I prefer to use the oil that the car maker recommends for the application as they actually test oils and use objective data to determine the proper oils to use. The car companies know far more about what works in their engines than anyone I've ever seen posting in a car forum.
Ad hype is not an appropriate basis to make an informed, objective technical decisions in my experience. There is no realistic means to determine the true lubrication performance of an oil short of using an extensive oil test sequence such as the ACEA A3/B4 which is the basis for many Euro car maker engine oil specifications.
http://www.acea.be/images/uploads/fi...nces_Final.pdf
YMMV
Old 12-10-2010, 03:35 PM
ivangene
Parts Specialist
ivangene's Avatar
Originally Posted by beentherebaby
The car companies know far more about what works in their engines than anyone I've ever seen posting in a car forum..
OH YEA, they would NEVER do anything stupid like put sealed bearing INSIDE a motor
Old 12-10-2010, 03:58 PM
Sneaky Pete
Sneaky Pete's Avatar
You mean her? Marc....I apologize in advance......its Friday brother..
Old 12-10-2010, 04:06 PM
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
Pete,
It's an "Oil thread" you get a pass on that one
Old 12-10-2010, 04:51 PM
gota911
Newbies Hospitality Director
gota911's Avatar
Pete,
I thought this was a OIL thread, not a tire pressure thread. Her "tire pressure" seems to be at max!
Old 12-10-2010, 04:53 PM
Byprodriver
Byprodriver's Avatar
So what oil & weight is she using?
Old 12-10-2010, 04:57 PM
gota911
gota911's Avatar
Looks like 3-in-1 Oil to me.
Old 12-10-2010, 05:09 PM
ivangene
Parts Specialist
ivangene's Avatar
Pete, you got a "pass" try for 2
Quick Reply: OIL OIL OIL !!!
