Track Tire Help
Track Tire Help
I looking at getting Nitto NT01's for my C4S. Does anyone know if 245/40/18 front and 315/30/18 back will fit on the stock rims. I am concerned about tire rub and the all wheel drive system. I have heard that if the size is off it can damage the diff?
Try Nitto website to see if dimension's are posted. diameter & revolutions per mile are critical for AWD.
You want the 235/40/18 and 315/30/18 setup. Worked like a champ on both my GT3 and Turbo!
Diameter is spot on at 25.39 and 25.35
And yes, those are on stock wheels.
The Penguin King
You've got a 4S, right? Even if you don't, I would think carefully before going to that much rear tire. You really don't need that much rubber to put the power down, and you will accentuate the understear that is built into the car. FWIW, I run 245/285's on my race car. You may not want to go to that low a front/rear ratio, but I personally think 315's are too much tire. ymmv...
btw, if it is a 4S, matching front/rear diameter is a very good idea.
Last edited by mglobe; 11-29-2010 at 08:25 PM. Reason: edited to make it look more like the english language
The Penguin King
You might be surprised. I've run 275/245 in NT01's on my car. They work fine on my C2. I don't really understand why a C4 would need more tire. 315's are going to make it very hard to rotate the car.
Without knowing the OP and his ability on track, there is no way to determine if he wants to rotate the car (more oversteer) or have some understeer dialed in. And yes, I agree, you can go fast with smaller sizes. I ran my fastest times at VIR in my GT with 250 fronts and 280 rears. A crapload of oversteer but that was fine by me
For mr. phoenix..........please get us some more info about what you want to do with these tires? I'm assuming this is for a track event not the street correct? What level of driver are you? Anything else and we could give you some better help on tire selection. I can tell you I have tried just about every track tire and brake pad combo out there and there are others like me on this board so use that knowledge base.
As far as my driving abilities I am a upper novice. When it comes to lap times I was able to do 1:19 all day on stock tires. To compare that with other drivers with much more experience driving M3 BMW's on track tires they are getting the same lap times.
I am not looking to become a race car driver just looking for less understeer, better and more consistent grip while not burning through my street tires.
One thing that might help much more is ARB's. Do you have the stock ARB's? If so, moving to the GT3 ARB's would be a huge help so you can actually dial in front/rear behavior commensurate with under/over steer.
I would do the 235/275 or 235/315 combo but know that ARB's will help you more than tire pressure and tire size. Also, alignment is another thing that needs to be examined. If you have a stock suspension then you are going to max out at 1 degree or less of camber up front and no matter what you do the car is going to push like a dump truck.
The Penguin King
Thank you all for you input and time on this. The tire and wheel setup will be for track use. Currently running the stock continentals the car is understeering in the sharp turns, not allot but enough to try to correct it. I have no oversteer at all. The tires are great for the first two or three laps but then the understeer comes in play. I have been playing with tire pressure and it does not help. I am not looking for oversteer just less understeer. The car is extremely planted and predictable.
