Rear LED's Installed
I am not sure. I don't remember seeing anything but they may be available.
So I ordered both the clear and smoked.
The clears came perfect.
The smoked came all broken up - I think they were former returns.
On MY Mk2 996 it will NOT work without wiring in parallel 50W 20ohm resistors.
Will post pics later this wknd
Nice, show us pics when you get it done!
for turn signals I bought 25w resistors
for stop light 50w resistors
you need to solder them in parallel to each of their respective wire harnesses.
i haven't tried a body fit yet - will do that next. if it sucks i'm not going to do it either.
It's not like it's an OEM product or anything. It's pretty crudely made...
I never had any issues because of the LEDs, I keep hearing about ECU this and and ECU that, electrical this eletrical that. lol if you are worried about having eletrical problems because of the LED's, I think the LEDs causing eletrical problems should be the least of your worries lol....just keeping it real...
Since I have had my car and before the LED's, let's see.. sunroof motor, both power window regulators (worn cabling), freon o-ring, starter mechanism....and this car is not my daily driver..
I only had to solder in 1 pair of resistors 1 on each side only for the turn signals.
When I got the LED's, my flashers were blinking way too fast which is what they call "hyperflash".
Then the research I did turned up this post on 6speed.
http://www.6speedonline.com/forums/9...-lights-6.html
