is this normal, sway bar related?
Looks like you've got adjustable droplinks. The rose joint looks slightly off centre, no expert but can't see why that would be a problem. I'm sure you could just twist it back in line with the other. As long as it's not binding I can't see any harm???
with the car on a level surface you should be able to remove the end of one of your drop links and replace it without having to force it. IE: the center to center dimension should be the same side to side, unless you are running circle tracks and want some weight "jacked" into it.
