996 Forum 1999-2005
The IMS discussion thread (Read this first!)
Old 10-10-2018, 12:31 PM
  #376
Charles Navarro
Charles Navarro's Avatar
Received 1,070 Likes on 556 Posts
Originally Posted by audi49
Looking at either a 996 or 986. Many don't yet have the IMS bearing replaced. As a DIYer with a garage (and a lift in the plans), is there a difference in level-of-difficulty in replacing the IMS bearing on a Boxster vs a 911? (And while I'm asking... which car is 'better' as a DIYer in general?). Thanks.
With a lift, it's certainly doable for the DIY owner. A transmission jack would also be useful, but otherwise check out the instructions for the IMS Solution to get an overview of the process:
http://imssolution.com/documentation-and-downloads/
The Bentley Publishers video also has a great overview of the process:
http://imsretrofit.com/ims-retrofit-procedure-overview/
We have free tool rental including RMS tool when you order an IMS Solution. Discounted tool rental is also now offered through LN when purchasing a Retrofit kit.
Old 11-28-2018, 07:25 PM
  #377
AA717driver
AA717driver's Avatar
What is the consensus on how many miles per year will circulate the oil sufficiently for it not to ‘spoil’?
I’m getting ready to pull the trigger on a car that just had the bearing replaced. Because I’m splitting my time between North and South, I won’t be putting tons of miles on any one car.
Thanks.
TC
Old 11-28-2018, 08:13 PM
  #378
AdamIsAdam
AdamIsAdam's Avatar
Received 3,809 Likes on 1,638 Posts
Thanks.
TC
It's not a consensus, it's LN Engineering gospel:
Service interval recommendations are valid only with use of Joe Gibbs BR break in oil during the new IMS bearing break-in period of 200-400 miles along with use of an LN Engineering Spin-On Oil Filter Adapter with subsequent oil changes at 6 months or 5,000 miles using Joe Gibbs DT40. Severe service interval is 3 months or 3,000 miles.
https://lnengineering.com/news/tech-...ice-intervals/
Old 11-29-2018, 10:21 PM
  #379
AA717driver
Adam—That’s really not what I was asking. The bearing tends to fail with greater frequency on cars that don’t get driven very often. I was wondering what constituted low useage that would give the oil trapped in the bearing a chance to corrode the material and cause failure.
IOW, if I drive 5000 mi a year, am I at significantly greater risk of a failure than if I drive 15,000 mi per year?
TC
Old 11-29-2018, 10:42 PM
  #380
AdamIsAdam
AdamIsAdam's Avatar
TC
based on the info various experts put out, the answer is this: as long as you drive it at least 20 minutes, and thoroughly warm it up each time you drive it, then you're not at higher risk of failure doing 5k a year vs 15k. (Assuming you change the oil every 6 months as well.)
It's the very short drives once a week where the oil doesn't have a chance to burn off the moisture, or the garage queen that's started once a week, idled for 10 minutes then shut down, it's those cars that are at high risk.
I never take my cars out if they aren't going to be driven for a while. (That's what my daily driver is for.) I also have a new Shelby GT350 and some of those are having mysterious engine failures, so I treat that the same way.
Old 11-30-2018, 10:33 AM
  #381
AA717driver
Thanks, Adam! Good luck with the Shelby—What a beast!
TC
Old 11-30-2018, 11:03 AM
  #382
AdamIsAdam
AdamIsAdam's Avatar
TC
Yea, it's a crazy car. Loving it so far.
Is that your Capri in the signature? I LOVE those! My father had one as a kid. They make good platforms for small block V8 swaps ;-)
Old 11-30-2018, 03:17 PM
  #383
jdoc1949
jdoc1949's Avatar
IMS bearing kit For Sale
I have a 2003 Targa with 74,000 miles, decided to drop engine and do bearing and seal swap before any issues.
Pulled it apart and found out that bearing was different.
Upon Inspection found out I had a new engine fitted in 2010 under warrantee at 49,000 miles by Porsche. Its the newer engine so IMS is not an issue.
I had talked to the dealer before and asked why they did not tell me, there explanation was they only keep records for 2 yrs, go figure?.
NEW KIT FOR SALE
So I have a LN kit and a new oem seal , I paid $547 for all as I had a coupon, the LN kits are now $650 plus seal $48 ( $698) value
I will seal all for $490 to member. I have photos and receipt, brand new, along with registration card for kit, I can send photos.
John
Old 11-30-2018, 05:41 PM
  #384
AA717driver
I had an identical Capri when I was in HS. The thing must have been built in the old Tiger factory in Germany. The sheet metal had to be an inch thick—it accelerated like it was. Fond memories though.
TC
Old 12-07-2018, 11:47 AM
  #385
AA717driver
Just to be clear, can you add the Solution without replacing the IMS? My car had the bearing replaced early this year and the previous owner put about 1,000 mi on it in the past year.
TC
Old 12-07-2018, 12:57 PM
  #386
Dranon
Dranon's Avatar
TC
The solution IS the replacement for the bearing. Read up on it at LN engineering and/or Jake Raby site.
http://flat6innovations.com/
​​​​​​https://lnengineering.com/education/...ilure-101.html
Old 12-07-2018, 06:15 PM
  #387
AA717driver
Got it. I thought you could add the pressurized feed to an existing IMSB.
TC
Old 12-07-2018, 06:22 PM
  #388
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,282 Likes on 899 Posts
TC
Thats a different type of oil feed, not to be confused with the IMS Solution.
Old 12-07-2018, 07:37 PM
  #389
Vincent713
Vincent713's Avatar
So there is a stand alone oil feed you can install and leave the existing original IMS bearing intact?
Old 12-07-2018, 08:49 PM
  #390
808Bill
808Bill's Avatar
Yes, there is a copy cat out there. Though a bit different than the " LN IMS Solution"
Quick Reply: The IMS discussion thread (Read this first!)
