Chirping noise when taking off in 1st or reverse
Hello all,
Quick question- As of recently I've noticed a chirping noise when taking off from a stop in 1st or reverse. Car is an '02 with 43k, original clutch. Is this an indication that I will need a clutch soon? Thanks in advance for your advice.
-Tim
"current MBA student trying hard to stay a Porsche owner"
-Tim
could be the throw out bearing. Does it make the noise only with the pedel depressed? If it does then that would be my guess.
I just had mine replaced along with a clutch kit.
What function said ^^^. Or, could be clutch plate/pressure plate "squealing" when under load because of glazing over. Just change it all when you do the clutch job.
I have the same thing, I was told it's the throw out bearing. My chirping runs in any gear, obviously the noise of the engine drowns is out but if you drive near a solid object you hear it again. slightest touch on the clutch and it's gone.
I don't think it's a big thing my clutch is only about a year old so I don't plan on pulling the tranny unless I have to, it's a damn shame it wasn't making the noise before the new engine went in.
