excessive left rear inner tire wear
I just replaced the rear tires on my 02 996 c2. I had stock alignment settings and the left rear inner tire corded early (right rear still had at least 4-5 more track days left on tread) . Tires are Toyo R888's. Most tracks I drive on are predominantly right turns (Road America, blackhawk, Joliet Autobahn).
Is this normal, or should I be adjusting camber and toe settings differently on the left rear, due to the track orientations being mostly heavy right orientation? If so, what are the recommended settings?
