997 stereo into a 996? Possible?
Has anyone fitted the head deck from the 997 into a 996? Can this be done?
The only creature comfort I am really missing is my aftermarket deck with bluetooth cel phone integration and ipod/iphone controls.
Since there is no PCM tied to my stereo I can probably just replace it with an aftermarket unit without voiding my warranty right?
Alternatively, anyone mount those permanent FM transmitter units? The ones that connect between the deck and the antenna?
Super Moderator
997 radio would be a challange...
To replace the head unit in an 04 you will also need to replace the amp and rewire due to the MOST bus.
Do a search, plenty of info here.
Well, I'm under the impression...possibly incorrectly...that the 997 deck has bluetooth integration, no? So I have handsfree with my phone and still have the Porsche system. I would have thought the two decks would use a similar wiring harness, simplifying the whole process but I guess not.
(I like the output...so I want to change *just* the deck)
I did do a search, I didn't find anything.
I guess I'll just buy an aftermarket system.
Check out:
http://www.beckerautosound.com
the last time i shopped new 997s hard enough to know the specs on the stereo was 2007 and there was no factory bluetooth integration or upgrade to my knowledge. i added it using the motorola t605 kit and the becker aux/phone cable. parrot also makes a good solution.
