Is my clutch is going?
My clutch has been acting strange, only when I disengage it. It doesn't slip, and the take up is smooth. But, when slowing down for a light, when I step on the pedal, the clutch disengages kinda roughly, feeling like a spring letting go, with a chatter kind of noise - as if I wasn't pushing the pedal down enough.
Anyone know if this is a sure sign that I need a new clutch? Or, is is normal behavior in these cars?
Thanks.
Thanks.
Parts Specialist
sounds like the disc is coming apart to me - or the shaft the throw out bearing rides on is gummed up?
just a thought.
Anyhow, try and give it a good "slip" where you rev it up and let it out too slow like a new driver. Sometimes if the disc is gummed up you can get a fresh spot by using it a little hard a time or two. Generate a little heat and burn any oil off too.
just a thought.
It could be oil or gunk somewhere, good point. Maybe the throw out bearing isn't throwing the disc out enough to disengage it properly? The car only has 21k miles, I would figure the clutch would be fine. I'll give it a little rough treatment and see if that works.
If your car's build date was before April 19, 2000, it could very well be the clutch release lever. The lever was modified after that date due to noise and function problems.
Does this mean I have to wait till the release lever/clutch goes, then get a new clutch w/ modified release lever?
Replace the lever when you replace the clutch, or sooner if it is giving your problems.
Thanks for the photo. I find at speed, the clutch disengages fine. But from first to second, I get that notchy, balky release. If it is the lever, I wouldn't have a mechanic take the transmision out without having the clutch replaced.
Does a bad lever cause premature wear on the clutch, or just cause noise and strange performance at low speeds?
I notice the problem on disengagement, at slow speeds. When I engage and release the clutch and nail it on the highway, there is no delay or slipping.
