The New Official "Things you didnt know about your 996" thread
#256
Ladies and Gentlemen,
With all due respect for your Constitutional right to free speech, I respectfully request we get this thread back on topic and stay focused. When originally placed as an Admin Sticky, all the general discussion items were removed. The intent of this thread was to be specifically limited to statements about 996 operational trivia that most folks might not have discovered after reading their owners manual. It was not meant to be a discussion thread, nor a questions and answers thread. That is what all the OTHER threads are for on the 996 Forum.
Sorry for the rant. I apoligize to those offended by it. But this is not the General Questions thread on which to pose questions and replies.
Thank you for your understanding in this matter.
Manny_911 (09-29-2019)
#257
Another thing I accidently found out about the 996 cooling system. If the coolant level drops too much (what too much is I dont know as there was nothing in the header tank when I checked) a red flashing light appears at the 250F mark on the temp gauge. The temp gauge was showing at just over 80F when I noticed it. I was in the process of completly changing or flushing out the old coolant via a long drawn out method of dropping 2 gallons and topping with water until only clear water eventually came from the drain plug. Then I topped off with 3 Gallons of coolant. Job successfully achieved without loosening or collapsing any radiator hoses .
#258
Exactly. I found that out on a track day. Hammer through a few long corners and the red light starts flashing. Panic mode as I return to the pits. Check the overflow bottle. Yup, coolant IS low. Top up and no problem.
#259
For any fellow Canadians out there that have bought US cars with speedometers in MPH, there is a way to get the digital display to change to KPH. Just turn the clock adjustment **** to the left, and hold for a few seconds and it will change your speed read out and well as the odometer readout to KMs.
#260
1. There is a terminal in the engine bay to jump/charge your battery (see pic below).
2. "A weak battery may be recognized...when the light emitting diode in the key grip no longer flashes..."
#263
Super Moderator
Sorry for the rant. I apologize to those offended by it. But this is not the General Questions thread on which to pose questions and replies.
Thanks!
Marc
TheUnscented (09-19-2021)
#266
On both my 00 C2 and 03 TT the rear fog light is on the drivers side. It could be so
Drivers behind you know where you are when YOU pull onto a shoulder due to
Heavy fog or rain or snow, etc.
#268
Acronyms
Just reposting these so others will easily find them.
Common acronyms used on this forum about your 996:
AOS Air/Oil Separator
CEL Check Engine Light
ECM Electronic Control Module
IMS Intermediate Shaft Bearing
LSD Limited Slip Differential
LWFW Light Weight Flywheel
MAF Mass Air Flow sensor
PPI Pre-Purchase Inspection
PSE Porsche Sport Exhaust
PSM Porsche Stability Management
RMS Rear Main Seal
SAI Secondary Air Injector
PDK (See the 997 Forum)
IIRC - If I recall correctly
TIA - Thanks in advance
WTB - Want to buy
RMS Rear Main Seal
WTB - Want to buy
The following 2 users liked this post by Thundertub:
danix (09-03-2020),
Sport'smodel (10-24-2021)
#269
An easy job with the 99 models. They have a mechanical engine and hood release which can be seen as the drivers door is unlocked manually via the ignition key. Electrical releases are not always the 'way to go' when shopping for a car. And for the 99 996 owners. The IMS bearing is the more robust double race type and less prone to failure. Thats statement I read straight from Flat6 Innovations. I hate to mention the dreaded IMS problems but thats something I only just discovered about my 996.
#270
OK something I accidentally found out with my 99 cabriolet alarm system. I had the roof down in the garage and the car was locked via the one click fob key. I needed to lean over into the back seats of the car to remove the small seat cushion. So incase I might set the alarm off, I clicked the key fob one time and heard the door unlock and saw the red alarm lights go off on the dash. As I was working on the seat, after just one minutes time I heard the door lock and the alarm re set itself. The car key was on a bench in the garage, not in my pocket so I did not catch the fob button accidentally locking the car again. I checked it again and the same thing happened. The next time I checked, I opened the drivers door and closed it. This action must have cancelled out the alarm and it did not re set itself or lock the doors. This time I had to re lock the car with one click on the fob key button. So if I have the roof down, unlock my car, then decide that I don't want to drive off in it, plus I do not open the drivers door, it will relock itself after exactly one minutes time. I dont know if this happens when I have the roof closed or with the hard top in place or what (if anything) the purpose of this posting is lol. Its just another thing that I didnt know about my 996.
