996 Forum 1999-2005
The Official "Things you didnt know about your 996" thread
Old 10-12-2009, 10:22 PM
  #106
jasper
jasper's Avatar
Here's one that hasn't come up yet.
The oil filler pipe can be unclipped from the airbox. There's a bellows section in the pipe which then let's you tilt the pipe up a good 6 inches to make adding oil a no-mess breeze.
Used this today when I did my oil change.
Old 10-12-2009, 10:27 PM
  #107
jasper
jasper's Avatar
A picture may help here:
Old 10-12-2009, 10:32 PM
  #108
knfeparty
knfeparty's Avatar
The little led that is in the middle of the dash right under the windshield lights up red in conjuction with the led on the key remote to let you know it is working.
PCM 2 has a lot of out-there features such as a setting for calibrating the trip computer for each time you get new tires.
It also can detect CD names / track names for most CDs, even if they are a mix cd made by the user. For CDs that don't have readable track data, you can enter the name of the cd in PCM 2 so that it will show up in the CD list for the CD changer.
Old 10-12-2009, 10:34 PM
  #109
gota911
Newbies Hospitality Director
gota911's Avatar
My wife asked me why I didn't come with this option!
Old 10-12-2009, 10:38 PM
  #110
redridge
redridge's Avatar
there is a coin holder in the rear center compartment.... yeah, a coin holder.
Old 10-12-2009, 10:54 PM
  #111
AndyK
AndyK's Avatar
Funny, I JUST found this out when reading a parts diagram on the center console! Those little fins are coin holders!? Go figure!
Old 10-13-2009, 05:24 AM
  #112
911_993_997
911_993_997's Avatar
Question
Originally Posted by ivangene
(1) If you fill the tank with the engine running the gas guage will not show full until you drive about 10 miles (or shut the car off, remove the key and turn it back on)
Why the hell would you fill the tank with the engine running?? Am I the only one who finds this odd?!
Lol.
Old 10-13-2009, 08:00 AM
  #113
frankfast
frankfast's Avatar
Is there anything that has to be reset after removing a dead battery from the car?
Old 10-13-2009, 08:44 AM
  #114
redridge
redridge's Avatar
need to input the radio/nav code... thats it. The ecu will adapt to your driving habits...
Old 10-13-2009, 12:50 PM
  #115
PasPar2
PasPar2's Avatar
what I learned looking for tranny oil for my 2002 996 tip:
The tip-S is is made by Mercedes Benz and is also used in many MB cars, as well as some Dodges and Chryslers. The transmission is called "722.6". It is considered "bullet proof" mechanically and mostly suffers from electronic issues rather then mechanical. Some 722.6's have a bolt on the torque converter to allow draining the oil - the 996 version doesnt not. This tranny installed in most MB models has a filler tube in the engine compartment but the dip stick needs to be purchased separately. The 996 version doesnt have a filler tube and gets filled via a fill bolt on the transmission.
the correct fluid for this tranny is the fuchs 3353 labels "Titan" available from Pelican parts. The gasket and filter look identical to the MB spec ones but cost 3x and 7x more respectively for the Porsche.
Old 10-13-2009, 01:55 PM
  #116
Tippy
Tippy's Avatar
Although not confirmed myself, I have read that the Tip cars have a direct pulley on the alternator while the manuals have a sprag type pulley.
I remember my Tip alt pulley was solid.
Can anyone confirm this?
Old 10-13-2009, 02:27 PM
  #117
wross996tt
wross996tt's Avatar
depends on the year of your car...MY 03+ radio code is stored in the DME.
Old 10-13-2009, 02:35 PM
  #118
wwest
wwest's Avatar
"..The ecu will adapt to your driving habits.."
And here I thought Porsche owners were too bright to believe that CRAP..!!
Maybe in the general case.
Even if the ECU does "learn", adapt, to some aspects of your driving habits those will be, MUST, be erased upon each engine stop/start cycle.
Old 10-13-2009, 02:40 PM
  #119
ivangene
Parts Specialist
ivangene's Avatar
Whew - Ferd,
I was thinking my car will be going slower and slower and slower if it learned I was an old man
Old 10-13-2009, 02:48 PM
  #120
Jim Griffin
Jim Griffin's Avatar
Yes the 996 Tiptronic S transmission is a MBZ tranny. As for the AWD cars, C4, C4S, Turbo, only the 996 Turbo Tiptronic uses another MBZ tranny (F-1) with different OEM part number and they are not interchangeable due to bolt pattern. If you build an aspirated 996 with more horsepower (ie supercharger) you may risk damage to the Tiptronic Transmission, if you were thinking "the Tiptronic, if it can withstand the bHP from a turbo, then it is okay for a supercharger" idea. Not.
Quick Reply: The Official "Things you didnt know about your 996" thread
