Headlamp Adjustment - DIY??
After almost 2 months of ownership, I finally drove my car at night. I noticed that the low beams were pointed a little low and it was a difficult to see in front of me at medium distance. There was not a problem seeing far away with the high beams.
Is this normal with the 996 light pattern or should I have them adjusted? Is this something that I can do, or should I take to my indy?
Assuming you have HID/xenon projector headlamps the beam is so much brighter and tighly focussed vs the old style halogen that there is a requirement that they have a shape "high" coverage cutoff for the beam pattern to prevent blinding oncoming drivers. If you raise the low beams your high beams will nicely illuminate the tree tops down the road.
It's a simple DIY. In my manual, headlight adjustment instructions are on page 233. Unless you have a really long philips head screwdriver, I find the easiest thing to do is to pop out the entire headlight unit and use a screwdriver to turn the screw. Clockwise on the lower screw raises the beam. You should be able to improve your night time vision (without blinding oncoming cars) to better see a 6' tall figure at a medium distance on the side of the road by turning the height adjustment screw on the passenger side between 1 - 2 full turns.
Yep. I have the Xenon headlamps.
Thanks for the advice on how to fix this issue. Sounds like the lights are pointed in the proper direction as per the design. They just do not help med distance visibility at night.
I found I can only raise the driver side lights a little bit without dazzling oncoming cars. The passenger side lights I can raise a bit more so I can see pedestrians, deer, bicyclists and road signs in the dark. After I adjust my lights, I go to a parking lot and have my wife drive my car and I drive her car. Then we go head to head a few times to check if the lights are too bright for oncoming traffic.
Correct me if I'm wrong but didnt the Xenon's have an auto leveling system or are you referring to something different (i.e this does not change the adjustment) I thought if you turned the lights on with the key out and then put the key in and turned it to the on position it would level the lights.
(I know I have seen it just not sure if that is what your looking for!)
Technically, they automobile auto-leveling is not, it is load leveling. As the suspension dips or expands, the lights react. I don't know if any car can even have true auto leveling, otherwise, everytime you went up a steep hill, they would point down to the road!
any idea what the upper screw does?
