Stabilizer Bars sizes
Hi all,
I will like to know about the diameter/wall thickness/Increased stiffness of the different bars that fit the '02 996 C2: (OEM Standard, ROW Sport M030, GT3 (996 or 997)and maybe 997 Carrera S). I have the 225/40ZR-18f & 285/30ZR-18r set up, with H&R springs + HD Bilstein shocks & standard bars. Looking to get a "near-neutral understeer".
Hi all,
If you aren't tracking your car, you probably haven't encountered any understeer that would require dialing it out. IMO, no street driving (i.e., way under the limit) remotely qualifies as a baseline for understeer.
As for the sway bar question:
OEM: front: 23.1, rear: 18.5
ROW M030: front: 23.6, rear: 19.6
GT3 front: 26.7, rear: 20.8 [~$1000 with links]
HR = front 26 mm; rear 23 mm [~$750 - no links required]
If you do track, and have a home track you will visit more than anywhere else, you can get away with a fixed (e.g., HR) front bar with an adjustable rear (e.g., GT3) bar. You can dial your car however you want, and just leave it.
Just keep in mind as the diameter of the sway bar is increased, stiffness increases to the 4th power. So increasing even small amounts has a dramatic affect on stiffness. A .5 mm increase (from stock to ROW) creates a ~10% increase in stiffness. And a 1.1 mm increase creates a ~25% increase. The GT3 increase (rear) is 2.3mm, and (front) is 4.6mm over stock. I think this equates to front =78% stiffer, and rear= 60% stiffer. My math could be off, and disregards thickness, but you get the idea.
Also, the front sway bar may require a different drop link, but most rear sways are direct replacement.
[edit: here is the PCA article on ROW vs USA M030: http://www.pca.org/panorama/sample_article_3.html]
BTW: I have a ROW M030 front and rear sway bar set, and a front GT3 sway bar with Tarett links for sale...
-td
https://rennlist.com/forums/2725180-post2.html
The thickness are different as well, and equally important. The GT3 bars are really big (but adjustable), I might suggest the sport bars instead, but the choice is yours. On my gt3 suspension, going from stock sway bars to GT3 bars, I noticed the car understeerd more with the GT3 bars; rear bar was on full stiff.
The balance of the ROW M030 suspension felt pretty much perfect when I drove such a car. It's hard to beat for the price, I just wanted something a bit stiffer.
This is why I asked before if you knew the spring rates of your current suspension. This is important and will affect the balance of the car (understeer or oversteer) once the car has taken a set. Find out this information first. Personally I feel like your car is set-up just fine how it is, get a good alignment and go do some track events
What do you mean by "near neutral"? What do you use your car for? DD? Track?
-td
-td
TD- Great info here and you seem to have a lot of knowledge regarding diameters and roll stiff ness. Care to comment on Solid vs. Hollow?
Thanks!
I'm running x74, bars are the same as the M030. FYI
Surely somebody has this answer handy.
Himself, how much are you asking for your set of ROW Sport MO30 Stabilizer bars?, Can you ship them?
Although I would like to sell these, personally, I would skip the M030 sways and go straight to HR/GT3 if you have track duty in mind...
-td
IMO, for the money, the best bang for the buck is to get an adjustable rear sway bar and a fixed front. It's not the optimal solution for adjustability on multiple tracks, but for most people it works perfectly.
-td
Resurrecting a thread.
What's the SOFTEST sway bar? I'm looking for a front sway bar that is softer than OEM to reduce understeer for autocross. I'm hoping that an aftermarket adjustable sway bar may have a softest position that is softer than OEM. Any ideas?
I don't think your car is acting normal with understeer going on. To many variables to go through. Could be anything like braking habits or mechanics of the suspension. Maybe even tire pressures. Anyway I'm convinced my car is set up for oversteer.
Parts Specialist
connecting rods?
drop links --- here is a pic
you need OEM GT3 sway bars and bushings - PLUS new drop links (the red parts)
