C4 is lots of fun in the snow w/ PSM turned off
We got over 8" of snow last night and the P-car had a chance to go out and play. It really wasn't much fun every time the electronic nanny stepped in to keep it in line, but after I disabled PSM the car came alive w/ power and power slides. I ended up in a neighbor's front yard last winter, so I'll have to learn to control my speed a bit- but it is so much fun!
This car is as much fun in the snow as any of the Audi Quattro's I've owned over the past 20 years. If you live in snow country w/ a C4, be sure to get out and enjoy it this winter.
Get out and enjoy it....
But a C2 would be even MORE fun....
Yes, but in a LARGE vacant no obstacle (curbs, lamp posts, etc.) parking lot.....
And unless the rear "virtual" (TC) LSD is disabled along with PSM the VC will remain flaccid regardless.
With a C4 you not only need to disable PSM but I would also do a few tight turns, VERY tight turns, "at speed" on a high traction surface to first cause the VC to become less flaccid, otherwise you might as well be driving a C2.
Yes, fresh snow tires for sure. It is very easy to pivot and control the vehicle and highly predictable thus far. There are limits in the snow that I have previously explored that I am not looking to revisit in the P-car.
More importantly with a limited slip differential, which many 996 C2s (mine included) do NOT have from the factory.
My 1991 e30 318iS has one stock, i mean common Porsche...
My WRX was a riot in the snow. I always pulled it out of winter storage after a fresh coating for some quick fun. It did donuts like it was a child's top; it would sit there and spin and spin and never deviate.
I miss that car.
I miss that car.
I NEVER(***) run on anything but nice and quiet riding, comfortably riding "summer use only" tires. It is FAR too easy to install tire chains in times of need and in the meantime I get to more thoroughly ENJOY my driving.
*** Well, other than the '92 Jeep Cherokee Limited RWD/AWD/4X4-hi/lo which remains in north central MT throughout the year.
Besides which on the really slick stuff, black ice, say, NO TIRE will be adequate absent studs or chains.
The nice thing is that snow, unlike many instances of ice on the roadbed, will be visually obvious allowing you the option of slowing down to remain in control. If I'm going to be caught unawares of ice on the roadbed I would much rather have the addition tread roadbed contact area of a summer tire vs the heavily "siped", or tread blocked, specialty winter tire.
Umm, that sounds really wrong to me. My summer PS2's barely stick to dry roads in cold weather, let alone ice. Siped winter tires are the way to go on winter surfaces, as long as the snow depth doesn't get out of control. Some non-studded tires these days have truly become great. I grew up with chains and I don't I'll ever use them again.
