Car won't take gas
#62
C'mon Krazy, no way. It was the fuse. I will fill with gas later today to verify. Must have shorted something out on that stupid 4-pin connector when doing my radar hardwire 2 weekends ago.
#64
Hi all I found that my Fuse was my problem, but not at first. I would to try other things like use little plumbers wire rotor tool for small pipes to keep flap open I did try that because I thought someone tryed to siphon out my gas and damaged the tub Thanks for all the info in the report I have a 2000 911 convertible
Medevack1 (01-06-2021)
#65
I'm sorry to bring this tread back from the dead, I have a 2004 40th AE and i'm having the same problem. Audion19s what lines did you zip tied and to what did you zip tied them to? I checked the fuse and it was ok im not sure if the 2004 40th AE E6 fuse is in a different location. please Help!!!!!
#66
The TSB regards fuel lines obstructing a flap of the fuel filler neck. Likely the related problem would start happening after work was done inside the fuel tank such as replacement of sending unit or fuel pump.
Here is a link to the TSB: https://www.porscheclubgb.com/legacy...dification.pdf
damage98MO (03-15-2023)
