996 Forum 1999-2005
Car won't take gas
Old 11-03-2008, 09:45 AM
Paul 996
Paul 996's Avatar
Andy,
Hope these help you out.
damage98MO (03-15-2023)
Old 11-03-2008, 11:55 AM
AudiOn19s
AudiOn19s's Avatar
Paul, Thanks man. Looks like I have another weekend project. This weekend I'm doing the valve adjustment on my M3...looks like next weekend I'll be fixing this fueling problem. It must have happened when I spun last time at the track? Weird since it was wet out and the spin was pretty casual. Didn't leave the pavement but I filled up right before the track with no issus then this issue crept up when I tried to top off on the trip home.
Andy
Old 11-04-2008, 12:37 AM
Fissionx
Fissionx's Avatar
Don't drop the shims
It's not that bad (i did it), feel free to shoot some questions at me. Considering how much you've helped me out, it's the least I can do.
Old 11-04-2008, 08:33 AM
AudiOn19s
AudiOn19s's Avatar
Ha...I bought a whole extra bag of shop rags to cover the drain holes just to be safe. I'm not anticipating any issues. Did my old bike's valve service and used to own a small block chevy that was a solid lifter motor that required what seem'd like monthly adjustments. If I run into anything I'll shoot you a PM though.
Old 11-04-2008, 11:17 AM
ivangene
Parts Specialist
ivangene's Avatar
Yea, we complain about servicing our cars, but remember cracked distributor caps, stuck points, adjusting valves, carburators coming loose every 3000 miles (Ford inline 6 owners know that one) resetting the timing and dwell.. these cars are a lot of work, but cars have always been work, just different types of things.
to the DIY'er
Old 11-04-2008, 01:19 PM
wyo996
wyo996's Avatar
This may not be relevant because I have an 02 but check to see if you have a cell phone plug behind the lower center consol. Remove the panel by your throttle pedal and tape over the cell phone harness. Then you can replace the fuse that shares the circut to the gas filler tube valve which is a safety mechanism for rollover fire protection. It is very easy to do before you tear into the tank. Will
Old 11-04-2008, 01:37 PM
AudiOn19s
AudiOn19s's Avatar
Already checked the E6 fuse...but I appreciat the input.
Old 12-10-2008, 06:25 PM
Navy'sporsche
Navy'sporsche's Avatar
Default reply
I have had the same problem once or twice but it eventually goes away. However, today the check engine light came on. Could these be related?
Old 12-10-2008, 07:06 PM
redridge
redridge's Avatar
I would get the code read... free at pep boys!
Old 12-11-2008, 02:31 AM
ivangene
Parts Specialist
ivangene's Avatar
He still owes us pictures promised from Thanksgiving W/E....
NO SOUP FOR YOU
Old 12-14-2008, 06:54 PM
SDP
SDP's Avatar
My 2004 C4S has similar issue--pump shuts down every few seconds. Guy at my local Sunoco turns the nozzle upside down and has no problem filling the car. (Strange, but it works.) He says its fairly common with Porsches.
Old 12-15-2008, 11:47 PM
MagnusB
MagnusB's Avatar
Does it pass any gas?
Old 12-16-2008, 09:39 AM
AudiOn19s
AudiOn19s's Avatar
Drove the car this past weekend and tried this...didn't work either.
I just need to find the time to get the fender liner out and figure out what's going on up there. Doesn't help that it's been really cold here the last couple of weekends.
Old 12-16-2008, 05:17 PM
kpl
kpl's Avatar
same issue only on some pumps, same solution....learned of that way back in HS when I worked in a gas station.
Old 12-16-2008, 06:13 PM
Nicolaasdb
Nicolaasdb's Avatar
I would love my escalade to not take gas...will make driving it a lot cheaper!!
Quick Reply: Car won't take gas
