Looks like engine replacement needed - advice needed
Very sorry to hear about the failure. As this unfolds, I'm sure everyone would be interested to hear what you learn about it.
My experience as a new Porsche owner.
I bought my first Porsche last August, a pristine 40th Anniversary with just under 11,000 miles. Fortunately, it also had some of the new car warranty with an additional 2 years CPO beyond that.
After owning for 5 months and 5,000 the engine (intermendiate shaft) failed while sitting at idle. These engines don't blow, that is break under the heavy loads of making power, they fail, seemingly without provocation.
Again I must note, go check out the boards of other marques (say BMW or Corvette) as see if you find anywhere near the volume of posts of failed engines. It is one thing if the reports were to the effect of " I was hitting the redline in fourth gear when....." as opposed to the typical Porsche engine failure, " I just started, (or was idling, driving normally, cruising etc...) when I heard a terrible noise (followed by smoke, oil and/or coolant). These engines don't blow, THEY FAIL.
The intermediate shaft bearing in mine failed without any provocation on my part. This was a known problem from 1999 an still persisted five years later when my car was built. I am unaware of any other quality car which has this propensity for catastrophic engine failure, especially one that persists for years unresolved.
To date Porsche has not explained the failure rate of this component or what, specifically, has been done to resolve it. I can only conclude either they don't know or it is a fundamental problem that is horribly expensive to remedy and thus the decision is made to let the owners assume the risks and costs,once warranty expires.
The best answer I have heard is something to the effect that the replacement Intermediate Shaft bearing is "better" although the problem apparantly persists.
I will have a hard decision to make approaching the end of my CPO.
It shouldn't happen. Got it. Now, if I were the king, I would only allow two kinds of posts on the subject: Posts about new failures we can learn from, and posts about solutions.
I think this is an excellent point, one that nobody has ever made before. It is now important that we generate a twenty page thread in which hundreds of posters each find a different way to say "this shouldn't happen", over and over again until everybody is paranoid and pissed off, and we drive 'engine failure' right to the top of Google page rank for any 996 search. Thanks so much for initiating this long overdue, neglected topic of discussion.
Fair enough, this topic has been gone over repeatedly. However it re-emerges again every time yet another Porsche owner's car has yet another catastrophic engine failure.
Porsche could end this simply by coming clean on the issue. What is so problematic about a simple layshaft? Why is Porsche unable to come up with a final fix? If this is something that cannot be remedied why not just say so and maybe do something to help those affected.
I love the way my car looks and drives but I am unaware of any other modern engine that has this kind of ongoing problem. Maybe a little less money should be spent on slick advertising and bit more spent on engineering. This is not something that wears prematurely, it fails without provocation or warning and is clearly not the result of driver abuse.
I intend to do oil analysis at the first oil change after the repair and certainly on the last oil change prior to the expiration of my CPO.
One last note, it is easy to complain about the repetive nature of posts on this issue.......if you haven't had it happen personally. These threads will continue as long as this problem is unresolved.
Here are some pictures I just took..
- it is still leaking coolant. The tank is almost empty and looks dirty
- can't tell for sure if oil is still leaking, and if it is mixed with coolant.
Don't know if this was posted before
http://www.autofarm.co.uk/pdf/911PW_Apr06.pdf
Seems to be a rational discussion of wet sump engine features and problems.
@ ssit,
Are you sure you just didn't blow part of the coolant tank?
You don't have any other pics of something obviously wrong with the engine itself?
Have you tried pouring distilled water in the coolant tank and seeing if you can find where all the coolant leaked from?
The clutch is something you will definitely want to consider. Carlsen is an OK dealer, but they still have tried to upsell me on stuff I haven't needed yet and their labor rate is $150/hr. You can do better than that. I don't believe that the dealer has to put the motor in the car to get the 2 year warranty coverage.
Good luck.
PS. I'm still not totally convinced that your motor is blown based on the evidence you have posted.
