H6W Litronic Parking Lights Led Replacement Update
I posted a thread a few weeks ago inquiring about certain topics pertaining to replacing the burnt out H6W bulbs in my litronic headlights with leds. Based on the comments posted in the thread, I made the jump and ordered a pair from www.42draftdesigns.com and I am very pleased. I opted for newer high output versions of the Bax9s led bulb that they recently began selling. The total for both shipped was $16, and for about the same price as I would have paid for replacement bulbs from Porsche, I am very pleased. Now we will see if they last the "life of the car" as promised.....
Included are two quick camera phone shots after I finished the install. Quality is poor, but it gives you a general idea of color and brightness.
Yes, those are the H6W parking/driving lights on a litronic headlight assembly. My stockers just burnt out and the options are basically to go Led for 8 bucks for 2 regular Leds or 16 for the brighter ones, buy stock replacements from Porsche for approximately 15 bucks (I think), or pay 30 bucks to have blue bulbs (Phillips Bluevision) shipped from Europe. It seems that this bulb configuration is quite rare in the U.S.
The color matches the Xenon headlights quite well, but the photo makes the lights appear brighter than they are. I would say they are about as bright, if not a little bit less bright, than the stock halogen parking lights. In the pictures above they look blindingly bright, which isn't the case in real life.
Newbies Hospitality Director
Here is a link to the site and the LED. 42 Draft Designs
Thanks for the compliment Edward, they do look much better than the stock halogen lights and were definitely a good upgrade for $16. Tim is correct, the H6W bulbs that Porsche lists in the manual have a Bax9s base so the push-turn Bax9s bulbs have the same physical dimensions as the stock bulbs. For anyone that is going to order, check out the specials page on the site before you do. Through the end of December they are running 15% (I believe) off on all their Leds, only adds up to a buck or two but I will take any discount.
By the way, out of curiosity, what are the city lights for. Did a search on the forum and the web and while everyone acknowledges them, nobody really describes what purpose the fulfill. Basically, I never really did understand their purpose 'under' the headlights. Incidentally, I don't remember having city lights on my 1998 BMW or 1992 VW. Maybe it's a newer model addition?
Not to rain on anyone's parade but bright "high" wattage LEDs REQUIRE adequate heat sinks and those look like they might allow the LED to last maybe a year of so. The is NO air circulation within the headlight assembly and the HB halogen plus the HID will make things a little WARM on their own.
The LED's themselves generally drop no more than 4 volts so a resistor must be used to reduce the 12-14 volts. That resistor is obviously mounted in the base thereby contributing to the overall HEATING level which MUST be "wicked" away if the LED is to have its forecasted long life.
You might want to find a way (relay??) to turn off the DRLs with the LB and/or HB on.
I have one of my driving lights out now. maybe I will upgrade.
Does it stay on with the xenon headlight on? I will check that tonight. It seems silly if it does.
As far as the purpose, I believe they are required for european cars and serve as daytime running lights in canada. I may be totally off in that regard but I remember reading something about that. They don't really serve a specific purpose in the U.S.
