H6W Litronic Parking Lights Led Replacement Update
#61
I purchased these from Pelican a little while ago for a far cheaper price, take a look there.
#63
7th Gear
Beware of the 42 Draft Designs BAX9S, they are not of great quality. The mounting barrel will eventually spin crossing the wires inside and shorting out the led. A little epoxy glue will prevent this but still, you shouldn't have to do that.
#65
Good LEDs
Hi all,
I ended up purchasing the same LEDs that ait109 did in his post above for my 02 Boxster S with factory litrnonics. They are called sold on amazon and listed as"H6W BAX9S LED Bulbs 8SMD Headlight Lamp...". HOWEVER, I do not recommend anyone use this particular bulb. It is very dim compared to the stock halogen bulb i.e. you are less visible to other drivers.
I then ordered and installed a different set of bulbs from amazon listed as " ". These particular bulbs are FANTASTIC! They are several times brighter compared to the previous and disappointing set I tried. They actually fill the lens with white light. I didn't do a direct comparison of these new bulbs to the stock halogen, but they are certainly bright enough and they look so much better than the yellow halogens in my opinion. Too lazy to go out there and take a SBS comparison picture, but just take my word for it that the brightness from this second set of bulbs is very good. They also appear higher quality than the first set. Get these ones. They are bright, they fit, and the car didn't throw any errors. If they burn out Ill post back...haha
Sorry for the freaking huge picture below... I couldn't figure out how to shrink it.
#66
I bought them from:
http://woodypeck.com/
They look much better IMO. Just leave some time for shipping to the US.
#67
Hi all,
I then ordered and installed a different set of bulbs from amazon listed as "FEIFEIER High Power LED Projector Light Bulb with SMD LED 7.5W white 2x BAX9s HW6...". These particular bulbs are FANTASTIC! They are several times brighter compared to the previous and disappointing set I tried. They actually fill the lens with white light. I didn't do a direct comparison of these new bulbs to the stock halogen, but they are certainly bright enough and they look so much better than the yellow halogens in my opinion. Too lazy to go out there and take a SBS comparison picture, but just take my word for it that the brightness from this second set of bulbs is very good. They also appear higher quality than the first set. Get these ones. They are bright, they fit, and the car didn't throw any errors. If they burn out Ill post back...haha
I am considering this one. The main thing I am worried about is the heat sink melting the inside of the headlight housing, or melting any wire that it comes in contact with. I could rig something up to get the heatsink on the outside of the headlight housing, but I would have to drill into the back cover.
Any thoughts on it compared to Feifeier?
#68
Am I the only one that just removed the bulb? I hate how it made the housing look when the headlights turned on. So just took it out. Serves no real purpose except to be a poor old school DRL.
#69
haha, I thought about putting back in my halogen bulb, but then I quickly decided to just leave the blown one out... I turned on the headlight and its hard to tell that the blown one is blown. I do want to get back LEDs though. I might have to suck it up and buy the which lasted 1 1/2 years. It looks great with the LEDs. When I am going through the tunnel, I turn on the park light rather than the full headlight. I dont like 'wasting' my HID startups for tunnels, since they are limited lifespan. I go through tunnels twice per day.
