H6W Litronic Parking Lights Led Replacement Update
Even my Landy has a separate bulb for DRLs. I guess this is the price I pay for living in what must surely be Porsche's least significant market...
Absent knowing the actual current flow I have no grounds for disputing what "the company" told you.
But the present "state of the art" for LEDs would indicate a fairly high wattage, high lumens, LED for supplying a light level even close to that of an H6W halogen, especially absent a colimator lens.
I don't know about ROW, but in Canada the DRLs are simply the low beams, at least on 996s of my vintage. It's actually a pain in the ***. You fire up the car, and you've got low beams, side markers, tail lights on all the time. The only thing that changes when you turn the headlights on is that the dash lights up. A lot of older 996s without Litronics develop a nasty looking burn-in because of it.
*** Was H6W but now 3 watt Luxeon LEDs with collimator lens for narrow forward beam focus. 9 ohm 10 watt resistor each side for ~1 amp current limit to LED, mounted within the back of the headlight assembly.
Ironman 140.6
I just ordered these. I will take pictures of one new LED with one original H6W bulb, and see how they match up.
Less than $20.00 for a pair delivered to Seattle.
Johnny
Johnny
7th Gear
This thread is not complete without comparing the BAX9s white LEDs to the old H6W halogen city lights. You are not going to get more illumination out of the LEDs but they are a better colour match.
And keep in mind that the atmosphere inside the headlight assembly gets pretty damn HOT with a 55W halogen high beam bulb and a 35W HID bulb inside.
The LED bulb to the right are the ones I used initially for corner/street/parking in my '95 LS400...
Both types have roughly equal brightness, color, and current draw/load.
Note that the cluster LEDs are mounted on a simple circuit board, no heat sink other than the printed circuit board 's solid metal rear layer.
They began failing with weeks of installation.
So I found the ones on the left.
The LED mount itself, as you can see, is something of a heatsink. Then add the screw on heatsink knurled cap...
None have failed after at least a year of use.
Ironman 140.6
Maybe you should have a look for comparison at the level/type of heat sink included in a simple household 40 watt LED bulb that only consumes 5-8 watts.
I have used just such led bulbs in my Boxster for years now (they are about as old as this thread). They operate with no heat sinks and have yet to burn out. On the other hand a high watt (relatively) led (such as your 5-8 watt in the A19 you mention above) would burn out in minutes without a heat sink to draw heat off the back of the led chip.
Welcome to 5 years ago. A 5-8 watt led in a 40w (equivalent) A19 is indeed a high wattage for an led and requires a large heat sink. Such a bulb will typically produce around 450 lumens of light. That is not what we are talking about for a an HW6 bulb that produces a fraction of that output.
And then adjust for headlamp HEAT containment.
Ironman 140.6
As I indicated previously I've had replacements LED bulbs similar to those referenced in the OP operating in my 986 and 996 for years with no failure and these bulbs have no large heat sinks on them similar to the type that are necessary to cool the far higher wattage A19's you described in your earlier example.
