ROLLED FENDERS
Originally Posted by jw996
Has anyone had their rear fenders rolled? How much and did it ruin paint? Thanks. JW
By the way, my rears were rubbing the outer fenderwell and it never wore off the paint, it rubbed all the time on large bumps.
Originally Posted by C4CRNA
What are rolled fenders?
Be aware that even a professional can make a mistake doing this and crack your paint or bend your fender. Not many shops will back this work. It's just too easy to screw it up and it's pretty expensive to fix.
Jim
Originally Posted by Tippy
You need to notch the sheetmetal as the fender is very strong. I had the weight of the left rear on a pipe. The weight of the rear was only on like a square inch and it did not like to bend, it is a double layer of sheetmetal plus spot welded, very tough. I gave up as I did not want to destroy my car.
http://www.tirerack.com/accessories/tools/fenderlip.jsp
Originally Posted by JimB
The old way was to do this with a pipe or bat between your tire and the fender. That's pretty scary. There is a pretty good tool that works much better.
That is exactly what I was doing but after mangling several wooden dowels, I opted for a nice thick walled pipe. Even then, she didnt want to give too much, you have to notch and then bend.
I'm not questioning notching. It seems like a good idea. I'm just suggesting using the tool. It allows you to very carefully control the pressure you are putting on the fender.
Jim
Tip,
Jim
Jim
Have you actuallly used the tool on the 996? I would think it could not roll the lip because of the suspension flexing downward, does look like a nice tool though.
Jim,
Originally Posted by gota911
I don't need to roll no stinkin' fenders!
I put 13" wheels on her and jacked 'er up 10"! Yeee-haaaa!
Ah man, that pic nevers gets old, glad I am not drinking anything.
