Remove CD holder, install CUBBY. HELP!
Ok, got a cubby, need to install it. Here's the problem:
Air-conditioner is on the bottom (with trim piece, diff size than above) CD-Holder is right above it. Cubby ONLY seems to fit in the bottom. So, I have to move up the AC-unit. Problem is, AC-Unit is too small for the upper shelf. It needs a trim piece to cover openings.
No problem, right? So called parts guy at the Porsche-dealer. He said that piece doesn't exist. WT hELL? HELP!!
I have seen a storage shelf for the middle. Look over at macarbon for some photos. If John is getting the parts for the shelf, then you should be able to as well.
Originally Posted by yizzung
Yes, there are two different cubbies (shelves). One for top and one for bottom. You need the top version...
The idiot at Parktown imports WILL NOT guarantee he can get me a shelf to replace my cd -holder. He says if he orders it and it doesn't fit, I'm stuck with it.
You can't put the AC in the upper shelf of the bottom center console...
That is unless you do a custom fabrication(which I have done)
You can only leave the AC in the bottom and get the upper cubby...
Originally Posted by jamie645
If it works out for you could I buy your cd holder from you?
Newbies Hospitality Director
Gant - why didn't you ask for help or do a seatch before you ordered this. I had covered all of this info in this thread at the end of April ot this year.
https://rennlist.com/forums/showthre...highlight=tray
