What is correct offset for a 19" rim on a 996 C2?
Pocket Sand
As per the title question...the rims i'm looking at are available in the following sizes, which are the correct offset/sizing?
19" x 11" 5/130 25
19" x 11" 5/130 52
19" x 8" 5/130 45
19" x 9.5" 5/130 49
thanks
19" x 11" 5/130 25
19" x 11" 5/130 52
19" x 8" 5/130 45
19" x 9.5" 5/130 49
thanks
There is no official sizing, as 19" wheels are not approved for 996 by Porsche
Using OEM wheels from Porsche - on my 996 C2 I have:
19x11 with 67 offset rear (as stamped on the wheel)
19x8 with 57 offset front
No issues with rubbing etc - std suspension on the car.
Originally Posted by juankimalo
To cdodkin:
Could you tell us the size of the tyres you wear in these Carrera S rims, please?
Excellent grip - nice ride - sidewall has a bead that protects the rim
Omar-
A good measure to start with is what the offsets are for your 18". I think you would love the 8" et45 for the front. But in the rear the 11" et 52 might be too far out for you. The GT3 takes 11" et63 in the rear and I couldn't imagine moving that out 11mm.
Tires are Toyo T1R in 235/35/19 and 315/25/19
Thanks.
235 front it's not very different from 225/30 R18, but 315 .... enormous !!!
It's oversize!! perhaps aesthetic is like a big foot but in corner stability, steering response, ride comfort, wet traction and so on wouldn't be the best compromise.
I've bought a set of Carrera S wheels off a standard body 2006 997 and i'm looking at tires now. I'm putting them on a 1999 996 cabriolet. I've decided to put 235 35 19s on the front but what should I put on the back? I absolutely don't want rubbing but I like an aggressive look. Do you have a rear shot of the 315 25 19s on the car?
Thanks! (and a classic, great looking car you've got!)
315 is a nice fit, not as stretched as the 295 on the rim - gives a good side wall with protection for the exposed edge of the rim.
Running 315 and 25 profile on 11" rims means that the tire runs higher than the 25 profile would suggest - and with the Toyo's being my #1 choice, I love it!
No rubbing on my 996, even with 315
Thanks for the pic. That looks really good!
Thanks, here's a rear shot of the car
315 is the better choice as it is closer to the 25" wheel design, less error than 295
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
235/35-19 3.2in 12.7in 25.5in 80.0in 792 0.0%
295/30-19 3.5in 13.0in 26.0in 81.6in 777 1.9%
315/25-19 3.1in 12.6in 25.2in 79.2in 800 -1.1%
And, What about of the equivalence? The geometry is changed
Aren't you modifing the gear box developments?
AnoTher question:
Did you mount N-specs tires?
Your car looks awesome. What a spectacular rear!!!!
AnoTher question:
The front tire wheel combo is the same 25" as the original spec wheel
The rear 315/25 tire makes the overall wheel/tire size -1.1% from original, but having a 315 width on an 11" rim makes the tire ride taller, and this gets you extremely close to the OEM size.
Limit on over/under size is 4% according to Porsche, so they're well within specification.
As for N rated - there is no 315/25/19 N rated tire that I'm aware of - there are very few 19" tires on the market to choose from.
The Toyo T1R is Y rated for speed 186 MPH or 300 KM/H - I am not concerned about their capabilities, or about using only N rated tires.
