Will this effect my ride? HELP!!
Ok Long story short, my right rear tires is 285/30/18 BUT my left rear tire is 285/35/18 do you guys think it will effect my ride or suspension? front are fine.
Ironman 140.6
You realize that the diameter of your rear differs by 4.3%? In other words if you are traveling at an indicated 100 mph one of your wheels will rotating at 100 mph and the other rear will be traveling at 95.46 mph (or 104.54 mph).
I would correct the problem if I were you.
Just out of curiousity, which side is the 35? If it's the right, perhaps Your car might make a good nascar candidate.
Honestly, It's a question with an obvious answer. If you had a $300 85 chrysler lebaron daily winter beater, you might not give a ****, but c'mon, think about it.
I got an 18inch rim on the left rear and a 19inch on the right rear...in front I got a 17 inch on the right and a 20 in on the left.....do you think this will effect my ride????
