Exterior Window Plastic/Rubber
What do you use on the exterior rubber on the bottom of the side windows to keep them looking good? How do you apply it so that it does not get on the paint or glass??? Thanks.
Poorboys trim restorer or Aerospace 303. Roll window all the way down apply let dry then wipe off.
Aero 303 is it!
Get a set of sponge paint brushes. Small(est) one works well on window trim, while larger works on tires, front lip, etc. Throw it in with your other supplies and use over and over.
Another vote for 303. |
+1 on the 303
Great! 303 it is. Where can I purchase it? I appreciate the info.
Here is one place. http://www.autogeek.net/303aerprot.html
You can get it at most "autoparts" stores. Kragen, Pep Boys, etc, etc.
