Cool Garage Door Opener Switch
for those of us with pre 02, targa switch isnt an option as it only comes with matte fininsh. pre 02s come with glossy finish so the switch would look out of place. ive been deseparate for a solution and this looks good and reasonably priced. just priced out switch from sunset and transmitter from a web vendor and we're already at $50. so plantraco, i dont think you overpaid.
as an aside, this guy on ebay sells the switch alone for 47... not sure why when sunset charges 18.
pre-facelift cars that have the matte finish buttons can make the button shiny by simply applying a gloss finish. It has been done before and posted. Do a search.
Remember.......where there is a will there is a Rennlister that will find a way
re
I dont think there's two button, I think he meant you will have two door lock buttons. One for the real door lock and the other for the garage.
Originally Posted by CosmosC4S
plantraco, where is the transmitter installed?
And why is there the need for 2 buttons?
I thought the garage door is operated with one single button,
push once to open/close...push again to do the opposite.
Originally Posted by signal
I wonder if someone has a hack like this for the "gate", you know like your gate remote for your community. Garage and Gate are the two remotes I cary...........ahh the joys of homelink
I think you could get 2 of them - there are many extra spots to put switches on the dash.
Yep, correct. You are adding another button to the dashboard and removing one of the inert filler plugs - your choice where you want to put it. This install has nothing to do with your original door lock button.
The button is wired into an included remote that you put inside the dash.
I was concerned that it would bounce around and rattle, but it does not rattle so far, and if it does, I just have to open it up again and zip tie it down somewhere.
The remote runs off battery, I wouldn't want to wire it into the car electrical system.
It's true, you do get the end result of having 2 "key" icons on the buttons of your dash, but that didn't bother me - I know what it does. I guess if you really want to you could change that button to another icon picture with a little effort. I saw the picture of the targa lift button, and I guess it's just personal taste about the icon picture on the button. I'd take either.
Originally Posted by plantraco
It took me about 2 minutes to install, and 1 minute to reprogram to my garage door.
.... The price was a bit high, but I thought it was worth it because the fit is perfect and doesn't junk up the car in any way and is totally reversible installation.
you can simply wire your garage door opener to function each time you pull on your "flash to pass" lever. A bonus is that you never again have to replace your opener battery, as it now uses 12v from the car.
Its a great hack that I found on the net early in my 996 life.
Originally Posted by Kims996Cab
If you don't wish to alter the appearance of your car at all; or don't wish to spend a cent, or even if you don't have a spare switch slot in your dash ....
There's so many "blanks" on the dash ... I think I'll put the Targa switch in just to fill up some of those damn blanks!
re
Hmmm very interesting... Is there a DIY on this forum?
lvdell... i would opt to do the targa switch if i felt that it would give it a seamless look. while im not averse to "glossing " the matte button, im not quite sure how the end result will be.
i tried searching here but came up zip. tried other sites, zip. do you know of a post?
has anyone tried lacquering it and what has been your experience?
thanks.
thanks.
Newbies Hospitality Director
thanks.
thanks.
https://rennlist.com/forums/showthre...ighlight=gloss
thanks tim.
i dont recall what combo i tried but gloss/button was def one of them. never thought to try gloss solo... i knew that it would give me 10 pages of threads on the exterior and waxing.... but you are my hero.
please help.. i dont have the schematics for the headlight/hi-beam wires. would anyone happen to know the color of the flash beams for an 03 c2?
I was digging around last night and was able to get to behind the carper and lights. I dont have to disassemble the headlight unit right?
tia
tia
