Help - serpentine belt/coolant issue
Hey guys, anyone know which accessory is the lower-most one driven by the serpentine belt? I assume it's the water pump?
The car is leaking coolant (not from the cap or reservoir - my coolant cap part number does end in 01, and the reservoir is dry, free of crust and appears to be in excellent condition) and the pulley on that lower most accessory is screwed. It's loose and wiggles, and the belt is off. I don't know if it's a bearing failure, or what. The part that concerns me, is that there is coolant leaking out (there appears to be a coolant hose right there, but I don't think it's coming from the hose) I'm thinking that the pulley has been in rough shape for some time, and has possibly worn through the housing of the water pump?
Anyone have experience with this?
Lastly, does coolant affect the paint? Should I wash it off immediately, or is it harmless?
Thanks in advance.
Jason
Thanks in advance.
Jason
Thanks, Steve. I apprecaite the input. I washed it off just to be safe.
Does nobody else know anything about the serpentine belt and/or pulleys? I'm starting the think it's the main drive pulley (the one connected to the crank).
Anyone? Any input would be appreciated.
Thanks.
Thanks.
