996 Forum 1999-2005
Lift Installed, Thanks for all the ideas.
Old 06-08-2006, 10:03 PM
gharold
gharold's Avatar
Default Lift Installed, Thanks for all the ideas.
Well, I finally completed my lift project and figured I would share some pictures. I have always wanted a lift, but since I do not have more than 8' of ceiling height and I am not moving anytime soon I had held off. So attached is my solution. It is a Bend-Pak mid rise lift. I recessed it because now that I am hooked on DE's and will be lowering the suspension I would not have been able to clear it. Thanks to everyone who I got ideas from on this forum. It is a great resource.
Old 06-08-2006, 10:14 PM
Palting
Palting's Avatar
That, is absolutely NEAT!!! Where can I get more info?
EDIT: I found their web-site. Good 'ole Google. Which model did you get? Any recommendations, tips?
Old 06-08-2006, 10:25 PM
Eric - Plug Guy
Basic Sponsor
Eric - Plug Guy's Avatar
Very cool! Is it adjustable? Does it hit the right jack points? How long can you leave it in the air? Cost?
Bolted down?
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Old 06-08-2006, 10:42 PM
gharold
gharold's Avatar
Info attached below. Model MD-6XP. It is not bolted down, it is totally portable, Fully adjustable and can hit just about any jack points. It lifts up to about 48" high. It has about 7 safety stops so it can be left in the air indefinetly with no pressure on the cylinders. Really a nice simple design. I would be happy to answer any other questions. Thanks.
Bend-Pak's Mid Rise Lifts - 6,000 lb. capacity auto lift
Suggested
Retail Price
$4250
Model
MD-6XP
Our Regular Price - $1480
Call for our Sale Price
FREE SHIPPING*
Model
MD-6XP
Style
Portable Lift Capacity
6,000 lbs. Lowered Height
4.75" Max. Lift Ht.
48"
With shortest adapters Overall Width
41.25" Overall Length
81" Standard Motor
110/220 VAC
Weight - 950 lbs.
Old 06-08-2006, 11:13 PM
Palting
Palting's Avatar
WOW! Sale price less than $1480. That is exceptional. I can't find that price on the Google hits. Where did you get it?
Old 06-08-2006, 11:35 PM
Alan C.
Alan C.'s Avatar
I bought a Rotary mid rise lift and love it. Projects I used to put off doing I don't worry about anymore. Wheel changes, brake flush and pad changes are a snap.
Old 06-09-2006, 12:17 AM
Itzkirb
Itzkirb's Avatar
very cool!
Gator911
Gator911's Avatar
Yea where did you get that??
It is awesome!! How did you modify your garage floor to accept the unit? Did you dimension the cutout in such away that it doesnt require fixing to the floor?
New idea for the new house
-Keith
Old 06-09-2006, 06:23 AM
jeff_c
jeff_c's Avatar
That has to be the coolest thing I've ever seen. I've always wanted my own lift.
I think this might need to be my next "mod"....group buy anyone?
Old 06-09-2006, 09:12 AM
gharold
gharold's Avatar
Guys,
I bought the lift from Automotive Service Equipment, http://www.asedeals.com/mid_rise_lifts.html.
I got the exact dimensions of the lift by talking to them and made the cutout in the floor about 1 inch larger on each side. It fits perfect and no need to bolt anything down. I used a diamond saw to make the cutout, then I broke up the concrete and dug it out to about 18" deep. Then I filled the hole with concrete and left a 5" depression to fit the lift in. Now when the lift is lowered it is flush to the floor.
Old 06-09-2006, 09:14 AM
TD in DC
TD in DC's Avatar
Originally Posted by gharold
Guys,
I assume you made a footing with rebar in the concrete hole?
Old 06-09-2006, 09:20 AM
gharold
gharold's Avatar
Actually, my house sits on the side of a mountain and 18" down is solid rock. I used 5000 psi concrete so I did not need to add rebar. 13" of solid concrete sitting on rock. Otherwise I would recommend going deeper and perhaps using rebar.
Old 06-09-2006, 10:34 AM
nycebo
nycebo's Avatar
Thumbs up WOW!
Greg.....NO NO NO.
You can't possibly do this to me! OMG! That has to be the coolest thing I have ever seen in a private home. It is absolutely fantastic and I am beyond envious at how easy your maintenance will be now.
The question now is how the heck am I going to arrange to install one of these contraptions. Between you and Dell, I have mods and mods for mods lined up into 2007.
Seriously, that is one spectacular installation. Kudos to you. I can already see your friends lining up on weekends for their 'maintenance intervals'.
Old 06-09-2006, 02:20 PM
Renaud Bizet
Renaud Bizet's Avatar
Hi,
This is just great !!!
Just a doubt, how easy it is to access the middle of the car.
Can you crawl in between to access these areas?
Thanks in advance for your answer.
Old 06-09-2006, 03:54 PM
Orient Express
Orient Express's Avatar
Default A few questions about your install
What happens in the little recess in the floor when it gets wet? Does it have a drain? How do you supply power (or is it air) to the lift?
Quick Reply: Lift Installed, Thanks for all the ideas.
