Oil Drip-left drivers side rear
Any thoughts...drop doesn't reach the ground, but is freshly produced after each drive. Is this the "cam cover"?
(Drip occurs at bottom of the black cylinder centered in the pic)
Vove, I've got a 99 as well. I figured valve cover or cam, or as AG suggested above-spark plug tube.
None of which are considered 'major' from what I understand, and can probably be left alone?
Left alone? No. Easy fix? Yes.
This is the second item I have seen you post about and keep trying to troubleshoot without dealer verification on your new (to you) car.
Why woldn't you bring these issues up with the dealer? They delivered a car to you with low coolant and oil leaking (now). Just take it back in and have them fix it.
Wish it were that easy Dell. Unfortunately I purchased off private seller across the country. Little recourse for getting anything comped at this point. I will be bringing the car in eventually, but being new to the P-car world, I'm trying to get an understanding of what is major and what isn't...before the local shop takes me to the cleaners.
So you're saying it's not alright to leave that oil seepage alone? As I mentioned, it never leaves a spot on the floor...only saw it when under the car.
Where are you located? I am sure there are guys here on the board that know of a good indy you can take your car to that will not cost an arm and a leg.
