Who has had engine replaced, and why?
#46
The engine on my 2003 996 C-2, 6-speed with 23,000 miles just died last Wednesday. I was driving in a residential area going about 25 or 30 mph when I heard a radio static-like noise coming from the back of the car. It then turned into a metallic clanking noise and continued to get louder. I drove back home and when I parked it, most or all of the oil began to leak from the front of the engine.
The dealership simply said something broke inside and I will need a new engine. PCNA approved the replacement. The service adviser said the “new” engine are actually better because it uses an old case but has all new internal parts that are all hand-assembled. I hope she’s right. I did some research and suspect my intermediate shaft bearing failed or the retaining stud in or on the sprocket broke off.
If everything goes well, I will be able to pick it up today and start the not-so-fun 2000-mile break-in again. Now I have to decide of whether to keep the car beyond the warranty period.
#47
#48
Hi fast1,
I am the original owner and I have never tracked the car although I had planned to take it to a DE or two. Because of this incident, I will not even consider a DE at this time. I don't want to give PCNA the remote chance to void my warranty. The car was always maintained by the local dealership and I had my last annual service/oil change in April of 2006. The car is 3.5 years old (built in 2/03 and purchased in 4/03) and now has 23,000 miles -- a semi-daily driver and used solely on the street.
I did the 2000-mile break-in, and always waited until the engine was completely warmed up before exceeding 4K RPM.
The car has been fairly good until last week with no signs of problems until that incident. When I first got the car, I had problems with the clutch (squeaking) and throwout bearing noise but that was eventually fixed after they pulled the tranny out. There was also two radio replacements.
I guess and hope this was just a freak incident and within the 2% error. Maybe I should play the lottery?
I'm still bummed out.
#49
Your replacement engine will have all the updated components. So, although it's sad hear that you are one of the few that need an engine replacement, the replacement engine should be a better one.
With regards to DE, sound out your local dealer. They are the one's who will OK it or not as warranty work, and PCNA usually just rubber stamps it. Porsche has the rep of a "street legal race car". So long as there are no signs of abuse, like melted clutch or type 2 over-revs, simply taking the car to DE usually does not void the warranty. So long as there is no abuse, chances are you will not need the warranty, anyway.
#50
Hi fast1,
#51
Thanks guys.
I just drove it back from the dealership and maintained under 4200 rpm that was difficult. The engine appears slightly smoother than the older one. However, this could all be in my mind. I did notice a rather rough idle while waiting at the lights. When I got home, I notice they forgot to plug in one vacuum line. I hope they did not forget anything else.
I asked about the warranty stuff and the adviser indicated that since PCNA provided this "reconditioned" engine under warranty, there will be no 2-year warranty and just the balance of the new car warranty.
She said the 2-year only applies if the customer paid for the product or if a 3rd-party like a independent warranty company paid for it. So my factory warranty expires this coming April 2007, but I am glad I purchased the extended 7/70 at the time I bought the car; I usually don't buy extended warranties.
She said this warranty claim costed about $11,000, but would have cost me about $13,000 had PCNA not covered the replacement. I also got a free alignment after the install. Apparently, they have to remove part of the rear suspension to get to the engine. Lastly, the engine is nice and shiny with lots of new external parts including an alternator and the oil cap that has the picture level to the ground like the 997s. I also see lots of parts made in 2005 and 2006.
#52
It seems like you are already doing it, but Ijust want to reinforce that you nned to break -in the engine like any other new engine.
I think not warrantying the engine other than the original car warranty is simply bogus.
#56
Originally Posted by LVDell
Gregg....what's the verdict though? Talk to the dealer about it? And goodwill, etc?
I am fortunate to live in a town that has excellent points of support for Pcar service (Kelly Moss, Lee's, etc) however in this case I have to give the dealer (Z European) and Z's Service Management credit where credit's due......they handled the situation professionally.
I'm not saying that a Pcar owner should be 'happy' with a $7000 event 11 months out of warranty however I've owned Pcars long enough to know that sh#t happens & when it does, can be significant.
I stand by my recomendation however..........that for an M96 based Pcar, if kept beyond warranty, have an Extended for engine & driveline.
#58
What about the *impartial* surveys or reliability?
Just a thought - almost all the reliability surveys at the moment are coming out with Porsche as number 1. Probably a more realistic statistic than asking "who's had problems". I'd love to ask this question on a GM or Ford board
Oh, and this also speaks volumes - http://www.jdpower.com/autos/brand-ratings/
#59
We are not talking about repairing hood latches, dash squeeks, or cold starting problems (for people still under warranty and who purchased in last 2 yrs, and who completed the JD survey). Yep, I got the JD surveys to fill out in the 12 months following purchase.
Engine or drive-line failure out-of warranty are a bit different.......and I don't think JD is sending me questionaires any longer, that I might enter that info
#60
July 26, 2002 RO 15226 mileage 50,222
coolant leaking out of left rear vehicle. Engine Hydrolocked.
Replaced under warranty
I believe this was the whole porosity failure issue.
