Who has had engine replaced, and why?
#31
01 C2, in 2004 coolant level kept going down, w/ no leak noticed, dealer found out it was mixing w/ engine oil and said that I needed a new engine - all under warranty. They replaced it with a new, not rebuilt, one. I was going to get rid of the car, but then thought about it and decided to keep my "old" car with its brand new engine, and bought an extended wrrnty.
#32
Just had mine replaced at 14k miles, cracked head. Was under warranty. dealer was great. First noticed problem when it starting idling like a 69 camaro. had it towed in and 3 days later, had it back with a brand new engine, did not cost me a penny
#33
Well.......on a quick search (and a re-read of the last few pages of the last Bob thread)......I thought this most appropriate a place to add my 'statistic'........a 37K, well maintained 02 C4 cab popped a timing chain & proceded to chew it up. My wife's car, and my occaisional drop-top weekend ride. Obviously never tracked....over reved...or missed a service date......this car could still be concoured.
Left 1,2,3 cam shaft is not turning. She's toast. Eleven months out of warranty.
Never before but now I'm an advocate of extended warranties (for M96 engines & drivelines going off OEM warranty). I was going to flip it in the spring......timing is everything.
#35
wow, This puts huge doubts in buying a older 996. The RMS, and cracking cylinders are common enough to be well known, and have been seen in enough mags. This is more than a little scarey, I don't seem to run in the same economic circles as some here who can drop 10K on a fix.
Man, make me wish Porsche would hire some engineers from Japan.
#36
Originally Posted by LVDell
Gregg....what's the verdict though? Talk to the dealer about it? And goodwill, etc?
Selling dealer is not local. Car is not at the local dealership, and there is more.......but I'm working on it......& will check back in with updates.
#38
#39
#40
Ironman 140.6
Originally Posted by Palting
I know that this is an unpopular topic. Not intending to flame anybody or anything. I know that there have been engine replacements. Please, pretty please, no ranting or arguing about quality, poor service or reliability. This is a simple request to list reasons for engine replacements, either on or off warranty. If it was for RMS, was it because the block itself was off spec or was it simply due to the multple leaks/replacements.
Thanks!!
Thanks!!
This issue has been covered more than once on probably every automotive forum in existence. The results are far from scientific. Rather they turn into a collection of random gripes and encourage trolls.
I have two M96 motors and neither has failed. This proves nothing. They could fail tomorrow, or they could never fail.
Palting, you are a great contributor to this board and you certainly know how to use the search function. Tell us what you are looking for and I am sure that many will try to help you out.
No flame intended btw
#41
My 2004 had the engine replaced at 4,500 miles. They found metal in the oil system. The car was broken in properly, never redlined, driven daily, and never tracked. PCNA replaced under warranty.
#42
this is an old thread. it's incorrect to judge "why you need this thread?" without knowing the context.
Originally Posted by Ray S
Why don't you do us a favor and explain why you need this? What are you searching for?
#43
Ironman 140.6
However, when a perfectly good search function exist "why do you need this" is a legitimate question.
#44
Hey....Pcar engines have failed through history.....the M96 was certainly not the 1st.
I would make the observation however, that for out-of-warranty cars, engine & drive line things that we used to tear down and fix.......often today have a different suggested 'remedy' (which is almost a non-issue to you if PCNA picks up the warranty tab for a rebuilt engine......not, if you just own the car, no warranty).......hence my suggestion of the Extended.
Again.........apologies for adding to this April thread
#45
Sorry, I didn't realize this was old.
Have you serached Bob's posts?
In all seriousness, there was a thread several months ago just like this that had a poll breakdown in it as well. Maybe that will help guide this one a bit?
Thanks for the replies so far, all.
Yup, did a search, Dell. Found a whole bunch of stuff, including that poll. I got a headache trying to weed out info that I needed. So I decided to post specifically.
Keep 'em coming!
Keep 'em coming!
Heh-heh . Don't get bent out of shape, 2000wrx. These incidents are few, but do get talked about a lot. I started this thread because I have had RMS replaced twice, and was wondering if it was out of the ordinary to expect a new engine under warranty if the RMS fails again. Eight months and 6,000 miles later, the new fix is still dry as a bone.
