Oil Preferences????
Oil Preferences????
I was told by a friend with a '99 996 that I should use Mobile Synthetic 15W 50. The Porsche owners manual suggests 10W 40 for my temperature If I remember correctly. In your experiences which has proved to be the best oil for your engine. I would never put mineral-based oil in but I’m not sure about the Synthetic weight. I live in San Diego, CA with very temperate weather generally above 60 degrees year round so I don't have to worry about - temperatures. Thanks for the help!
-Andrew
-Andrew
I am also in San Diego, and I feel that since we have cuh normalized, constant tempatures, that we are in the best position to use quite a thick recipe for oil. I specifically use Amsoil 20/50 racing oil. Its red, so when its not so red anymore, I change it, and its supposed to be long drain, so if I by chance have to go 5k with it in there, I'm okay.
At walmart, 15/50 mobile is 4.50 a quart. The way I see it, my 7.50 a quart is not that far off, and for a better oil, which is proven in various tests. I bought that "preffered customer" thing with Amsoil, so I have that 20% discount thing. I buy enough with two 9 quart cars!
HTH,
Brendan
HTH,
Brendan
Use the factory recommended Mobil One 0W-40. You can get it from your local ExxonMobil oil distributor (check Mobil's web site).
Using a heavier oil is unnecessary and will cost you some power. Also, the thicker oil is not as desirable for cold starting.
S.
S.
Super Moderator
Needs More Cowbell
Needs More Cowbell
FixedWing,
Have you been able to purchase Mobil1 0W-40 from a local ExxonMobil distributor?
I have been unsuccessful here in MA (Boston). Seems as though they only sell 0W-40 to dealers. Every retail outlet who sells other grades of Mobil1 tell me they can't even order it for me.
[quote]Originally posted by ltc:
<strong>
</strong><hr></blockquote>
Yes. I bought four mini-cases from the distributor in Connecticut, L F Powers Co in Waterbury.
I paid retail though had I bought a pallet then they would have given me a discount.
I'm surprised. You are the first person I've heard reporting a problem. In fact, friends also buy their aviation products that way. So if they don't want your business try another one. To find a distributor look here:
<a href="http://www.prod.exxonmobil.com/channelpartners/mn_distributor_directory.jsp" target="_blank">Distributor Directory</a>
S.
<strong>
S.
Im hearing a majority response for 0w-40. I am not very informed on the specifics of oil weights. What does the 0W stand for? Does that mean it is a very thin oil? Same for the 40. what would be the difference between a 0W and a 10W? Thanks for the help
-Andrew
-Andrew
