Supercharger went kaboom
Or so I thought. Blew the feed oil line. Cruising at 85 down I25 and the CEL came on and a few seconds later blue smoke in the rearview. Immediately pulled over and oil pouring out the left side of the engine. My first thought was what will a new engine cost. Closer inspection and now with a calmer mind I checked the oil lines in and out of the SC. Down at the block fitting on the feed line on the left was a nice liittle 1/4 inch hole worn by rubbing on a metal hose clamp from the radiator. Evo is sending me a new hose and I think I can get to it without removing the SC but we will see. Thanks for a large oil reserve, the dipstick and electronic oil indicator showed only one or two quarts low..If you have an SC especially C4S I would suggest checking that area for any rubbing as the engine torques. It took 8,000m to wear through. Steel braided lines would be ideal but I plan to but some protection of somekind for now when I replace the damaged line. Just one of the prices you pay for aftermarket fun. Will
phew! i thought your engine blew. i really want supercharged 996 engines to last (be it EVO, TPC, RUF...) to prove that the m96 engine is a strong engine and that it's not the redheaded stepchild in the porsche family.
This hose has plenty of clearance if it is installed properly. The hose is too stiff to move with any engine torque, and since all related components are attached to the block, everything moves the same amount anyway. Just make sure you check for proper clearence when you put the new hose on and the belt is in place. You will need to remove the tube between the blower and the aftercooler and release the belt at that point to make it easier to get to the connector on the block. Check to make sure your belt is not too stretched as a floppy belt could occasionally hit the oil hose. (as well as cause your SC and other accessories to slip)
If you need piece of mind, take a short piece of thin wall conduit (3/4") and slide it over the hose down to the bottom area. If the belt hits occasionally, no damage will be done to either the belt or hose. But, like I said above, if you position the hose connector at the correct angle, you will have plenty of clearance and have nothing to worry about.
Supercharger when kaboom
The belt is not at all close to the supply oil line, only the return line which I first suspected. I will try to post pictures of the hose when I get it off. Clearance on my car connot be increased due to the coolant clamp and hose are fixed very near the exit of the supply line from the block. Either the clamp may be rotated out the way or perhapse a 45 degree fitting from the block. For now I will shield that 2 or 3 in segment with something like copper or aluminum pipe split and slipped on the new hose. I don't think plastic will hold up. Again a stainless steel braided hose would be ideal. Will
Originally Posted by wyo996
The belt is not at all close to the supply oil line, only the return line which I first suspected. I will try to post pictures of the hose when I get it off. Clearance on my car connot be increased due to the radiator clamp and hose are fixed very near the exit of the supply line from the block. Either the clamp may be rotated out the way or perhapse a 45 degree fitting from the block. For now I will shield that 2 or 3 in segment with something like copper or aluminum pipe split and slipped on the new hose. I don't think plastic will hold up. Again a stainless steel braided hose would be ideal. Will
I wish I had a fiberoptic camera to show the actual location in situ because I hope to fix it without dissmanteling the whole system, but if I do remove the SC I can get better pictures. Again this may just be on the C4S. I had a similar problem at first install last year with a water coolant line that was cut by the belt on first install and used a shield and fitting to rerout the line. I had one of the first C4S SC'ed at the time and Nacelle in Canada who did his at that time had similar problems. I just want to pass on my problems with everyone to help them avoid the same thing. Will
Originally Posted by Hotbasco
This reminds me to carry a roll of duct take (manco brand) in my 911! Glad to hear it was a happy ending!!!
VERY GOOD IDEA.....
-Eli
