$13 DIY muffler bypass pipes.
I am driving the 996 in One Lap this year and have been putting the car on a diet for the last few weeks. My goal is to get the car under 2900 lbs with a half tank of gas.
I carefully removed the ENTIRE rear interior of the car:carpet, speakers trim etc.I then moved to the front and removed the spare, tool kit etc. That brought me to about 3000 pounds. I then put studs in the rear holes of the passenger seat bolts so that the seat can be easily removed every morning when I arrive at the track. I installed a GT3 sport seat that does not have the comfort seat motors. Down to just under 2950.
I had wanted to buy FabSpeed muffler bypass pipes but the $495 cost is just way too high for a limited use(track day and One Lap) product. So I measured the pipe coming out of the cats 2in and went to Pep Boys. For $6.99 each I bought two pieces of right angle pipe. They fit perfectly without any cutting and I was able to use the factory clamps. The entire install, and muffler removal took about 20 minutes; figure a bit longer if you do not have air tools. If you do not care about the BLING factor of the FabSpeed polished pipes this is a great cheap mod.
I have not done an official weighing, and corner balance but the car should now be right at the 2900lb goal.
Alex
Alex
This is very cool. I knew there had to be a cheap way to do this. Can you post pictures?
Is there a way to clamp on tips?
And the big question - How does it sound? Neighbors hate you?
Great story and solution. Have you considered a few other areas of lightening? I noticed in your Avatar that your car has the rear wiper. Have a look at how much that motor weighs. It's easily accessible from inside the car, behind that rear trim panel. I'm sure that there are plenty of other areas where you can shave some weight as well if you haven;t hit your target.
I am going out of town, but if I can take a picture before I go, I will post it.
At the track have seen several Cup cars sporting plain pipes. To my taste there is a reall appeal to the totally functional, understated look. All business and a big sound.
The sound has been discused here many times. My take is that it is not near as loud as I had feared. At 3000 rpms it is very livable. Would my wife tolorate them as a permanant addition, NO. But, they are quite enough that I will use them for One Lap and track days. I think that the weight savings will be worth the 20 minute hassle of switching the pipes and removing the mufflers.
Hanging head in embarrassment. Sorry about the typos in the last post; must proofread.
Alon, the rear wiper is history. Any other thoughts? I am getting a little concerned that it will take me an entire weekend to put all of the parts back in the car after the race. : (
As for the twists, they are my track wheels. I will be using 5 spokes for One Lap.
I will try to post a pic tonight but it won’t show you much. Just imagine the big, plain, unpolished exhaust pipes coming out the back of your parents station wagon in the 70’s and you have a pretty accurate image of the 996(without the fake wood paneling).
Alex
Alex
Remove the front sway bar? It will help redice understeer
What about going to a smaller, lightweight battery like some of the GT3 guys?
Center, lower console (not much but it all helps)?
Remove bumper reinforcement bars (easy to remove bumper skins for access)? They must weigh at least 30 pounds each...
Headlights swapped for empty housings (headlights pop out in one minute each) but I don't know how much weight you'd save there and how hard it would be to find another set of housings and empty them out.
Hmm, what else?
Hmm, what else?
Pocket Sand
Originally Posted by C4S Surgeon
Anybody know what decibel level the bypass pipes produce on a 3.6 996? Some of the tracks I go to have a 89db max, but I would love to try my bypass pipes there.
i'd be interested also in finding out the real number as i have to get under 97dB.
Front bumper DIY is here somewhere, do a search for "third radiator DIY"
Rear bumper? Even easier than front but I'll have to find you that one somewhere, unless anyone else knows exactly where it might be.
Alex,
Two things. First, assuming you have the clamp that is female on both ends, offset the clamp to one side and either weld it or bolt it to the bypass. That will keep that connection secure and give you a longer clamp area to attach to the Cat. Does that make any sense? If you don't the clamps will vibrate loose. How do I know this? I had my own bypass pipes made a couple of years ago and had to tighten them every few days. I actually lost one at Sebring. (sorry if any of you were behind me)
BTW, I paid $20 at my local muffler shop. What a rippoff!
Second, please don't remove your bumpers. Small bumps sometimes happen on the track and you would do major damage without them.
Jim
Jim
