Help....I'm topless :)
Hi, perhaps someone here can help me with a question. All of a sudden, my top will not go up (or down) using the button on the dash. I have replaced the switch - that did not fix the issue. I can, however work the top using the key in the door. Any other suggestions of what the problem could be?
Thanks in advance. |
Originally Posted by knsb10
(Post 19007731)
Originally Posted by Carlo D
(Post 19008194)
check the hydraulic fluid level. If so go to harborfreight and buy a Crc hydraulic fluid to top it off. No need for Porsche brand .
Check your fuses. C3 - power top from the key. D3 - power top from the switch. B1 and B5 too, just in case. EDIT: this guy had your problem and it was B5 https://rennlist.com/forums/996-forum/949902-convertible-top-problem-fuse-b5-continuously-burned.html |
(Post 19007731)
Thanks in advance. Not sure about the requirements of the door lock activation of the top, but for the dash switch to operate the top,,, parking brake switch must be activated with dash parking brake light on, and the engine lid micro switch must be in the shut position. I've seen the engine lid switch not fully engaged with no dash lights showing, not letting top work. TCM has to see the lid is closed. After cleaning the micro switch and lock mechanism and lubing it , top switch worked again. Does your top light flash on briefly..? when trying to open/close. If so, some parameter is not being met and TCM will not allow top to operate. Most common are the park brake and engine lid. |
Does the handbrake indicator light up when you lift up the handbrake? The key in the door doesn't require the handbrake to be set but the dash switch does.
Originally Posted by wyovino
(Post 19008518)
Hey folks - I am in this similar situation, parking brake light on dashboard stopped working, and so the top isn't responding to the up/down button.
The key method works, so almost positive the e-brake switch is bad. BUT - there seems to be two potential parts, and one is cheap ($10) while the other is expensive ($80). Here's Pelican's "Handbrake Switch for Warning Light" which they say fits my '99. Here's Suncoast's same part which they say DOES NOT fit my '99. Not sure why they say that. Instead I have seen on a few sites this part number which the refer to as a "center console microswitch." So, pretty sure the Pelican part (996-613-11202) that costs $10 is what I need, but I am am hoping to be sure that's what I need, and not the actual (#966-613-20500) microswitch. Anyone done this already who can share a little insight? Thanks! EDIT: Ok, I figured this out, the microswitch is for the console lid for when setting the alarm. Duh. |
| All times are GMT -3. The time now is 06:28 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
