19” Porsche Lobster Claw Wheels - On 996.2 - ?
Hello All,
I just can't seem to figure this out and looking for an assist.
Nothing specific at all about this in existing thread or anything much really that I can find yet in the forum or online.
QUESTION:
Can you put 19 Inch Porsche 997 "Lobster Claw" Wheels on a Narrow Body 996.2 ?
DETAILS:
Front wheels are 8”- et57-19” - - - Tires are 235/40/19
Rears are 11”-et51-19” - - - Tires are 295/35/19 i
I am trying to learn and figure this out but just don't understand the verbage/detail on wheels yet. Any help is appreciated.
Project Idea is to powder coat these black and see how it works out on a Speed Yellow C2 Cab
QUESTION:
DETAILS:
Further research and I found this existing thread: https://rennlist.com/forums/996-foru...ch-wheels.html
Seems 19 inch wheels have worked and are ok but not likely for track. Still Investigating
The following 5 users liked this post by 4Driver4:
808Bill (03-30-2021),
barbancourt (03-29-2021),
Fracture (04-06-2021),
moosetaco (03-29-2021),
PRSH-B450 (05-22-2021)
Copy that. Thank you and that looks great.
Going to give this a go Soren.
Note: Will get new rubber which is fine as these are winter tires anyway on these.
Cheers
Cheers
Last edited by T-LOCHA; 03-29-2021 at 01:46 PM. Reason: Correction Addition for Clarity
Hey Soren
Do you know if your wheels are marked or confirmed ET57 on the Front and ET51 on the back?
Same as the ones I am looking at?
Did you notice a difference with the ride at all in anyway.
Thank you again.
T-LOCHA
Thank you again.
T-LOCHA
They should fit with no problems, here is my recent thread fitting Carrera Sport wheels on my 996.2.
https://rennlist.com/forums/996-foru...-nb-996-a.html
Thanks Fransico. Learned a lot here on that thread.
Hello All,
QUESTION:
DETAILS:
QUESTION:
DETAILS:
Narrow body lobsters will fit. I believe your rear wheels are for a wide body.
For example, narrow body wheels are 19x11 et 67. I’m running 295/30 19s.
Here they are on my car in narrow body fitment. The wide body would stick out too far.
soren.911 (03-30-2021)
I don’t know the exact ET but they are original 997 carrera S wheels.
The car is more stable now especially in side wind than before with my 18”
I’m having continental sport contact N rated tyres on the lobsters and they are very good.
Please take a picture of your wheels when you have a chance, specifically the numbers stamped on the outside near the valve stem on the rear wheels. I can’t imagine how you have even et67 wheels on the back with 15mm spacers, never mind et51. My et67 wheels sit nearly flush without any spacers. I’m running a 14mm spacer in the front.
Thanks Diddy,
I agree. I almost pulled trigger on these wheels butbelieve the rear wheels I documented would be to large for narrow body also.
To confirm your rear lobster fork wheels are ET67 and fit, and the front wheels I documented would work also.
So it is just the rears in the wheels I posted that are wrong as thet are spec for a 997 wide body.
Front ET 57
Rear ET 67
Like I said 15mm spacers front and NO spacers rear. 👍
diddy2003 (03-30-2021)
Thanks Diddy,
Fronts are 19x8 et 57 with 14mm spacers. 235/35/19s
Narrow body wheels are fairly easy to find. A few sets have been in the marketplace here recently.
Thanks. That's what I figured. I must have read it fast. I don't think I could even fit a 3mm spacers in the rear without rubbing out the outside. I copied your front spacer look this winter. I replaced my 10mm spacer with a 14mm after seeing your car.
