Took my car for clutch replacement!
My clutch finally gave in, It started slipping a little until the point where even moving the car needed several thousand RPMs. I ended up taking the car to a reputable indy and got a new clutch put in! There was no material left on the clutch, it was essentially a metal disk.I also got a RMS job done and found out one of the previous owner's let someone smear grease all over the IMS bearing :banghead: I assume this is the "hold my beer" version of an IMS fix hehe. Anyways I got that cleaned up and found that I should get new shift cables, as I occasionally have a second gear grinding issue, when my tranny oil was checked it was clean so hopefully that will fix it. I have to say the car feels SOO much better thanks to getting the new clutch! However, it seems that I will need a gym membership since I don't own the million pound clutch anymore! Any recommendations for the cables? I liked the Numeric feel but it might be too pricey. Is it worth the extra cost?
Originally Posted by TheYoung911
(Post 15962583)
Was the seal still in place? Did you leave it or yank it out? |
Had my clutch done just because I was having the IMS/RMS done and they said it was trashed, only 50k miles on it but it sure felt better afterwards.
Originally Posted by 4Driver4
(Post 15962713)
Weird. I would think the engine oil would have washed that away. Musta been some nasty stuff.
Originally Posted by motoo344
(Post 15962766)
Did you sort out what let oil into your coolant?
Have no experience with the Numeric cables - although I do plan to buy some soon. I have the shifter and its the only one i'd recommend getting. |
(Post 15962883)
They think it might have been silicon grease or something, it was really bad like the whole area was black. I got a new RMS put in, asked about the IMS they said it looked fine so no need to do it.
In hindsight it was, but the reality is that my car is either getting 1. Sold or 2.Never being driven in 2 months due to me going to college. At this point I'm minimizing expenses. I asked if it was fine and shop felt confident it was good. If I end up keeping the car, then I'll splurge on the LN refit.
Fingers crossed!
Originally Posted by dan_189
(Post 15962948)
(Post 15962971)
(Post 15962883)
Missing the chance to replace the IMS is a bad move and will cost you more in the long run - I have my fingers, toes and anything else I can for you crossed your next thread isn't "I should have replaced my IMS bearing like the internet told me to".
Reading that someone packed the IMS with some sort of lube is a red flag - skimped on the IMS... what other presents has the previous owner left for you... |
old candy and a credit card, i assume to help pay for my new IMS :roflmao:
Seeing that I've made a bad mistake, I'll get some money together and take care of the IMS when doing my next round of repairs. I'll be doing shift cables, CV joint, and IMS as of now.
