996 Forum 1999-2005
water pump replacement fun
Old 07-12-2019, 12:45 PM
SoundnSpeed
SoundnSpeed's Avatar
Originally Posted by Imo000
Tap it to the next size bolt, drill through and use a nut, epoxy the hole and drill/tap a new stock size one, use a small wisegrip to squeeze together the pump and the block (leaving the pliers permanently in place), JB Weld the pump to the block or use RTV to seal the pump to the block AND leave the vent valve permanently open on the overflow tank. That's about all I can think of right now.
OK, I'll admit that my fall back was to figure out how to grind the thermostat housing just enough to fit a nut behind this hole....super happy I didn't have to go there!!!
Old 07-12-2019, 12:48 PM
Kuwaiti
Kuwaiti's Avatar
Good Job, well done
Old 07-12-2019, 01:58 PM
pdxmotorhead
pdxmotorhead's Avatar
Originally Posted by cds72911
You may know this, but there are several different length bolts on the water pump. If you put one that is longer in a hole that should only have a short bolt, it bottoms out and you keep on cranking, it could strip out the aluminum threads on the casting.
Chasing threads is usually done with a tap.
FYI, there are special "taps" specifically to chase threads,
They typically don't have a taper, they are more like a bolt with slots in it.
I have used a Dremel to put a couple slots in a hardened bolt to "chase"
the threads clear prior to torquing.
Old 07-12-2019, 03:11 PM
cds72911
cds72911's Avatar
That's why I said "usually". I've done the same with modified bolts or a bottoming tap for blind holes. Listing out every possible option to someone who doesn't know what chasing threads is overkill, IMO. YMMV.
Old 07-12-2019, 04:29 PM
De Jeeper
De Jeeper's Avatar
Received 3,276 Likes on 1,709 Posts
Amazon Amazon
One of my favorite purchases.
SoundnSpeed (07-12-2019)
Old 07-14-2019, 02:06 AM
pdxmotorhead
I just felt like leaving the end of the answer to posterity.. I'm always surprised how many people don't know about thread chasers, broke tap extractors, and uing left hand twist bits to remove broken bolts and screws..
Quick Reply: water pump replacement fun
