Massive white cloud. Lots of oil in intake.
So doing about 75 mph in the interstate and i see a mass of white smoke from my car. So I head to the side and shut it down and come to a stop, After a minute I try to crank it but it just clicks. So I tow it to my house and i notice that there is no oil leaking but my oil gauge is like 4-5 clicks low. I take off my TB and there is a ton of oil in the intake manifolds and even in my exhaust. Is this a classic AOC issue or do you think there is a major problem. Engine is pulled out now and i will be taking it apart later today. Just fishing for ideas and things to look for.
AOS, and hydro locked from the sound of it. You may have dodged a bullet by it not starting again.
Received 1,085 Likes
Classic AOS failure. Replace AOS then clean it up, add oil and pull the spark plugs...cycle the engine with the starter to expel oil that reached the cylinders. I would first hand crank the engine after removing the spark plugs to make sure everything is turning correctly.
Not only AOS directly ... also failing oil
rerurn pump in one of the heads can cause the AOS being flooded and dumping vast amounts of oil in the intake.
mod your AOS get rid of this Achilles heel
Probably not the cause ... if it was, your engine is scrapnelled ... but it was just an example of what else could go wrong to cause the AOS do its magic and inject loads of oil straight in the inlet... kabooom
No, not reluctant. I just want to check and overhaul everything i can while the engine is sitting on the floor instead of having to mess with it in the car.
Then, it's a good time to change all those vacuum lines, water pump, RMS, injectors, coolant tank (if original), inspect your Y-cable as they fail too.
