check engine light
check engine light
Have a code P2096 (Post Catalyst Fuel Trim System Too Lean Bank 1) with a check engine light. Is this serious and can it be ignored or reset? What is the fix? 2002 911
P2096 Signal Delay Time for Oxygen Sensor Ageing - Above Limit
Possible fault cause
- Oxygen sensor
Try clearing the code and see if it comes back. If it does, replace the oxygen sensor which is not difficult to do.
- Oxygen sensor
Captain Obvious
Super User
Super User
I just had a Porsche mechanic read the computer and the only error code was the 02 sensor New cats at 91000. Reset code and drove it for 15 miles and CEL is not on.
Didn't you replace all 4 7K ago?
Move the sensor to the other side.
Captain Obvious
Super User
Super User
How many miles have you driven it since clearing the code?
