996 Forum 1999-2005
996: Engine Noise and CEL P0300, P0304, P0305, P0306
Old 05-24-2019, 07:27 PM
ajvalles1
Cruisin'
ajvalles1's Avatar
Default 996: Engine Noise and CEL P0300, P0304, P0305, P0306
Hello, I'm new to the forum here. I started up my 996 today and had a really rough idle, followed by engine shutdown and CEL Codes: P0300, P0304, P0305, P0306. Also shot a quick video of what the engine sounds like when i start up the gas. I momentarily did press on the throttle to get a better sound of it. I'm thinking that the engine is totally done, and would need a rebuild or a swap. Thoughts?
Also a reference to a great Porsche Mechanic in the Orange County / Los Angeles Area would be greatly appreciated
Link to Video
Old 05-24-2019, 07:29 PM
bull3t
bull3t's Avatar
When were the spark plugs and coils changed?
Old 05-24-2019, 07:32 PM
ajvalles1
Cruisin'
ajvalles1's Avatar
About 25k miles ago
Old 05-24-2019, 07:49 PM
808Bill
808Bill's Avatar
Don't start it again!
Old 05-24-2019, 07:51 PM
ajvalles1
Cruisin'
ajvalles1's Avatar
Noted. Any insight on what it may be ?
Old 05-24-2019, 07:55 PM
808Bill
808Bill's Avatar
.Wait till a couple of our experts see this and chime it.
Old 05-24-2019, 07:56 PM
wildbilly32
wildbilly32's Avatar
Misfires may NOT mean the engine is toast. 4-5&6 cylinders all on the same side might be a significant indication. I would stay on the electrical side of problems at this time. Hard to say from the sound of your recording as only half of your engine is firing. That will make it sound pretty funky. I would not run the car any more until further troubleshooting.
Old 05-24-2019, 08:10 PM
Porschetech3
Porschetech3's Avatar
Received 4,320 Likes on 1,958 Posts
I hear low compression on at least 1 cylinder on tick-over. I would start with compression test followed by checking cam timing. Or even start with checking cam timing, then compression test and borescope for valve/piston contact..
I have a feeling the noise is the valves contacting the pistons from a failed IMS shaft/ gears slipped.
Old 05-24-2019, 08:56 PM
Chris(MA)
Chris(MA)'s Avatar
Bad ground wire on one cylinder bank?
Old 05-24-2019, 09:39 PM
ajvalles1
Cruisin'
ajvalles1's Avatar
Maybe any advice on how to look for that?
Old 05-24-2019, 09:48 PM
808Bill
808Bill's Avatar
Would it not make sense in the case to pull the belt an rotate by hand to see if anything (metal to metal) is making contact before starting?
AJ, out of curiosity, what year is your car?
Old 05-24-2019, 09:58 PM
ajvalles1
Cruisin'
ajvalles1's Avatar
It's a 2003.
Old 05-24-2019, 10:04 PM
Porschetech3
The first thing I would do is rotate by hand to TDC and pop out the cam plugs and check the alignment of the timing gears. I would not even attempt to start it again until cam timing is verified !!
Old 05-24-2019, 10:10 PM
808Bill
808Bill's Avatar
Broken timing chain maybe?
Old 05-24-2019, 10:31 PM
ajvalles1
Cruisin'
ajvalles1's Avatar
My guess is what am i looking for here? Cam plugs are the Green ones correct?
Quick Reply: 996: Engine Noise and CEL P0300, P0304, P0305, P0306
