wiring
Received 1,085 Likes
I downloaded the repair manuals and wiring diagrams as pdf files from somewhere for free. Can't remember where but I'll take a look. I tried to upload the pdf's but they are too large.
I find the Bentley manual to be great, but Alldata.diy has them too. I like the book, since it is forever (Alldata is an annual subscription), and I don't need a computer handy for the paper book. Alldata is good for some things because it has details that book doesn't, but I think wiring diagrams are the same both sources.
You may have to dig around a bit here https://workshop-manuals.com/porsche/
Or here https://cardiagn.com/porsche-911-car...ir-manual-pdf/
cut and paste the google drive link. That will take you to a download web page. The file is an RAR file (compressed) you can open with WinZip.
So just a recap to help other members
The fault was passenger window worked perfectly, except when you lowered the roof the passenger window did not lower with the other windows.
But if you lowered the window via the switch it would then raise at the end of the roof closing sequence
Checked the roof ECU for a control signal output which it had.
Traced wiring to the motor all good no water damage, so new motor fitted all works fine
