RMS needs to be done, what else to do while in there?
Well at first my leak was a slight weeping, then a drip, now it's making my garage a bit messy so looks like we're going to have to go in and get the RMS replaced.
My father and I will be taking on the task. He's owned an auto shop for the last 26 years but sold it last year to retire and move closer to us. In any case we'll be doing this in a home garage but he has a stash of specialized tools and tons of experience with all types of vehicles including German cars.
I figure with the RMS I might as well replace the clutch and possibly flywheel. IMS was already done about 6 years ago but with 175k miles what else?
I'm thinking maybe the AOS as a precautionary measure? Replaced it too about 5 years ago. What about the chain guides? Aren't they plastic and require replacement?
Anything else you can all think of? I wanted to hold off on this until the car was showing signs of a complete engine rebuild but it's still pulling strong so aside from this oil leak it all looks good.
I think you have the major ones planned already.
Your engine has 175K miles on it?
Are you planning to drop the whole engine out?
If your IMSB is 6 years old, I think it technically is due for another replacement. That decision is up to you though.
I did this job a couple of years ago, I did not remove the engine though. RMS requires a tool so that you dont push it too far, some members here have a plastic tool to prevent this, maybe try to borrow it? Since you are taking the flywheel off, you will need new bolts as well. Some other items are clutch, flywheel, clutch fork, white lithium grease around fork.
How did you determine that the leak is coming from the RMS?
With that many years since it was serviced, I'd consider doing the IMSB again. If so, don't forget the various loctite products you need (flange sealant and green wicking).
And O-rings in the power steering lines. AOS, do it!
Good point on the IMSB. I'll make a list of pros and cons and figure out if I want to include that in the repairs.
Dealer and indy both came to the same conclusion. Might not be a 100% diagnosis but you truly never know until you start taking things apart. I do know that every time I clean it up the leak comes back from the same spot which is the where the engine and transmission meet. So we'll prepare as if it's the RMS but understand we could find out it's something else.
Even though I've had the car 10 years I still have the records from the previous owner. The RMS had to be replaced once before so the one in there is not the original.
Member Chris(MA) sells a reasonably priced 3D printed tool to install the RMS at the right depth. Not sure if you "need" pressure plate bolts, but they're cheap, so I always replace them. Depending on age, and condition, the clutch actuating arm, guide tube, bolts, pivot, spring clip, bushing, etc, can be serviced (there is an upgraded part from a TSB, note that the updated parts don't fit the old style arm and pivot).
So even with the LN bearing it's still recommended to replace regularly?
Yeah I know the AOS but good point on the O-rings, thanks!
http://imsretrofit.com/service-intervals/
"Dealer and indy both came to the same conclusion. Might not be a 100% diagnosis but you truly never know until you start taking things apart. I do know that every time I clean it up the leak comes back from the same spot which is the where the engine and transmission meet. So we'll prepare as if it's the RMS but understand we could find out it's something else.
Even though I've had the car 10 years I still have the records from the previous owner. The RMS had to be replaced once before so the one in there is not the original."
I've found that many service people kind of "slow walk" you into complacency or a sense of comfort by giving you the best case scenario when diagnosing mechanical problems. Then, once you've given them your car and they've taken it apart they start telling you the real skinny... In case you don't already know it, the IMS flange and the RMS leaks both look the same from the outside so it's equally likely that it's the imsb flange or both. I'm not trying to scare you or imply something bad is going on, just saying go in with your eyes open. Good luck
That is correct. All of the LN retrofit bearings (excluding the plain bearing IMS Solution) have service intervals measured in both miles and years.
So it's closer to 8 years and probably 60k miles since the new bearing was installed.
So you are doing the work yourself... $4k is probably on the high end of what it'll wind up costing you - even with a bunch of "extras" and tools (water pump, LT thermostat, AOS, oil pump hex key and spring, cam chain tensioner pads, Coolant tank, Clutch, miscellaneous hardware and hoses, etc...). ** If you're interested in buying the LNE IMSB tools let me know via PM (I did the solution so I've got both sets - but not the "Faultless")... I'll make you a deal! FWIW - LNE will loan you the tools if you buy the bearing from them... Good Luck
