What is this part on the passenger side?
I took off my passenger side coolant hose on the top of the engine right above the engine mount and noticed this black thing that is plugged into the top. There is some kind of long hose of some kind attached to it. Looks like some kind of 45 degree elbow valve.
Located just to the right of the electrical wire connector
Any ideas what this? Just thinking it could be an easy replace while your are there item?
crankcase vent valve (check valve). it connects to the long gnarly AOS hose. real pain to get that retaining bolt started on my boxster. Not much to the part so I don't think it requires replacement.
Received 1,084 Likes
#6 here http://www.autoatlanta.com/porsche-p...section=104-10
click on the part number for a picture of the crankcase breather
Yup, breather, hose goes to AOS as stated above. Easy to replace, the one on my 2000 had a leaky o-ring, so I swapped it out. I wouldn't replace it unless it is leaking or damaged.
The breather is attached by 1 bolt to the head. Remove it & pull up on it, making it easier to release the AOS hose by pinching the integral clamp. Check the o-ring for damage.
You don’t need to detach the hose on the AOS side. It has a plastic clip so you can detach it on the Y vent end.
I've tried several things including squeezing the hose, squeezing at 6 and 12 o'clock and 9 and 3 o'clock. There are no gray colored clips showing where or how to squeeze. What am I doing wrong?
Having some problem getting the hose detached from the plastic elbow vent. Got the 10mm bolt undone and the elbow is free.
