Slave cylinder leaking after extending it to max
Hi,
With my slave cylinder disconnected I accidentally pressed the clutch pedal all the way down, it goes much much deeper with the slave cylinder disconnected. And the rod extends way further.
I noticed some drips from the rod coming out of the slave cylinder, did I blow the internal seals? Or is this somehow expected? Did it leak because the pin went to far out or did something break?
thanks
thanks
It’s been superseded by Porsche a few times already so you probably did yourself a favor unless you already had the latest.
Me too. Sucks when it happens, but at least the slave cylinder doesn’t cost a fortune. I learned a good lesson. As someone said recently, I didn’t waste money (buying the part) I paid for training (lesson learned).
