996 Forum 1999-2005
Blown Motor!!??
Old 04-07-2019, 11:25 PM
  #76
808Bill
808Bill's Avatar
Originally Posted by Coopduc
It seems to me that something this size could only come from the oil filter cannister, the oil pump, pressure relief valve, or the oil pickup tube. These are the only things between the screen and the filter. Everything else would have to pass through the screen on the end of the pickup tube. This assumes the screen itself is intact...Hmmmmm
I'll get to the sump tonight or tomorrow after work.
Old 04-08-2019, 12:57 AM
  #77
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,282 Likes on 899 Posts
Originally Posted by Ahsai
I really hope Jake is right about the seized alternator. Since the smoke was on the left side (crossed from bank2 cylinders) so the bank1 long transmission bolt theory should be less likely.
If you had smoke from the tailpipe, I doubt I am right.. The screeching and other traits pointed to the alternator, but not smoke from the tailpipe..
Old 04-08-2019, 01:10 AM
  #78
Ahsai
Ahsai's Avatar
Argh...I missed that.
Old 04-08-2019, 01:27 AM
  #79
808Bill
808Bill's Avatar
All pully's are turning with no wobble or binding.
Old 04-08-2019, 11:59 AM
  #80
Surroues
Surroues's Avatar
Originally Posted by Flat6 Innovations
I’m thinking the alternator seized. The rubber burning smell is the key to this. Screeching is a trait, and so is the smoke from the driver’s side.. It would not come from the tail pipe, but in the mirror it would appear to.
996AE, Bill and I had several messages back and forth when he put this used engine in the car. I was very frank with him in those chats, as I always will be.
Why would a seized alternator create a hydrolock?
Old 04-08-2019, 12:02 PM
  #81
MattBurns
MattBurns's Avatar
It won't cause a hydrolock but it will keep the motor from turning over.
Old 04-08-2019, 12:09 PM
  #82
Horsepwr
Horsepwr's Avatar
It wouldn't, but I think the point they are trying to make is a seized pully can make it so you can't turn the engine.
Old 04-08-2019, 12:10 PM
  #83
Flat6 Innovations
Former Vendor
And it would cause the screeching sound, and the smoke... UNLESS the smoke comes from the tailpipe.
I have had many cars come here with "seized engines" misdiagnosed, and all they needed was an alternator.. One of these was Ed from Florida, he was a RL member on this forum, and his "blown engine" was addressed for less than 500 bucks when he sent me the car, and I properly diagnosed it.. That was over a decade ago now.
Old 04-08-2019, 12:24 PM
  #84
dporto
dporto's Avatar
Received 1,153 Likes on 790 Posts
"One of these was Ed from Florida, he was a RL member on this forum, and his "blown engine" was addressed for less than 500 bucks when he sent me the car, and I properly diagnosed it.. That was over a decade ago now."
^^ That would be LUCKY ED FROM FLORIDA!!!
Old 04-08-2019, 01:28 PM
  #85
Prelude Guy
Prelude Guy's Avatar
Crap! Sorry to hear! Hopefully it is something easy to resolve.
I was about to suggest checking the tensioner pulleys.
A few years ago I bought a 2006 Civic Si. The previous owner said the engine locked up. Bought it for a steal.
Long story short, one of the tensioner pulley bearings melted and seized up. I think I have the pic up on my Instagram.
Sounds like yours are fine though. :-(
Also, just a heads-up, don't assume the smoke you saw coming out of the tailpipe is related to the culprit. Dont let it prevent you from simple troubleshooting. The smoke could've been related to something else.
Old 04-08-2019, 03:57 PM
  #86
808Bill
808Bill's Avatar
Ok, I give up and have to ask. HOW THE HELL do you get #4 coil unplugged and out without pulling the muffler and brackets. I can't get my hand up high enough to pull up on the connector. It is unclipped though.
Also, how would you get the coil out, bend it down/forward and pull at an angle? Been on this for 45 min...Not to mention I woke up at 1am sick today!
Old 04-08-2019, 04:01 PM
  #87
jobyt
jobyt's Avatar
I pulled the muffler to get at #4 when I replaced the coils, spark plugs and tubes. Not sure how you can get in there w/o moving everything....
Hope this turns out as a fixable issue that doesn't require a rebuild!
Old 04-08-2019, 04:39 PM
  #88
rogazilla
rogazilla's Avatar
Just saw your question in other thread, I think if the car is high up enough like on a lift its easier to get it off. Like you I worked on my back with car on jack stand and for the life of me I could not remove it. I ended up just remove the muffler. It is actually easier than I thought, 10 minutes to remove the muffler when I had spent 20 minutes hurting my hand trying to get the coil out (I just decided it is impossible).
For muffler removal, remove the 3 bolts that hold the bracket and take the whole thing down. I tried to remove the 2 vertical bolts that hold the muffler to the bracket and that ended up being a fail because one of the bolt is too long and wont be able to come out without the bracket being removed.
Old 04-08-2019, 04:42 PM
  #89
808Bill
808Bill's Avatar
Finally got it off. On to the other side! I can't believe how tight this connector was.
Old 04-08-2019, 05:37 PM
  #90
808Bill
808Bill's Avatar
#4 full of oil. Now to pull bank 1
Quick Reply: Blown Motor!!??
