Has anyone installed a Guards LSD on a c4s? If so, noticable difference in handling?
obviously, this would be primarily directed for the track since doing an LSD on the street is pretty pointless with the 911. In the past 15 years, I've never really needed an LSD (other than not having actually driven a LSD'd 911 on track).
So, now that i'm doing a 4.0l install, the question arises whether I should consider 1. A lightweight flywheel as the rotating engine assemblies will be balanced and 2. Would an LSD really make that much of a difference.
Looking forward to getting my 911 back on the road after a 2 year hiatus and a proportional amount of dust covering the car in the garage.
No exactly apples to apples but I recently eliminated a "clunk" (felt lake a bad U joint) coming from the diff by installing a WaveTrac unit, I haven't had it on the track yet but even in spirited driving there's a noticeable improvement. A LSD/TBD would complement your build very well.
As for the LWFW my only experience was in a 2.0 Turbo talon with moderate motor work, for stop and go driving it required a lot of bliping the accelerator to maintain RPM's to get rolling.
EVERY 911 needs a LSD.
LucasNo993t (03-24-2023)
The front diff on your car isn't really doing anything anyways, except giving it a better F to R weight balance.
I have a C4S with nearly identical mods to your, I can't wait to get an LSD; I hate how the power is cut every time there is uneven pavement.
Would you mind telling me more about your sunroof delete? What was involved from a parts sourcing standpoint? How much did it cost you, how are the results, did you get a new GT3 liner? Is it a factory roof or CF? I hate my sunroof so much, and would LOVE to get rid of 40 lbs way up high AND lose the rattles.
Thanks!
Thanks!
I never had an issue with cutting power (I always have had PSM off).
The sunroof delete on my car is factory as I ordered the car that way. While you can get the steel panel itself easy enough, the hard part will be the headliner and the rib structure underneath to acquire.
Thanks!
Thanks!
The awd inhibits fun in sprited canyon driving in my turbo as it limits the ability to kick the tail out, but the way it claws it’s way out of 2nd gear corners at the track is awesome. Even if all four wheels have broken loose, you you don’t get the rear end wanting to come around the way you would in a rwd car. As noted above, you’ve got to have the psm off otherwise it will just cut power.
This one is a bit confusing. Assuming the PSM is off, if one of the rear wheels start spinning, the aggregate rotation of the combined rear wheels will be greater than the aggregate rotation of the front wheels, and the VC will immediately transfer power to both of the front wheels. So there will be 3 wheels with power applied. The VC is kinda like an LSD operating between front and rear wheels, like an LSD operates between 2 rear wheels. I can't see that an LSD will help much for tracking, except perhaps in very extreme conditions, perhaps if there was lot of gravel or water on the track. . Certainly would be useful for off-roading or a icy road, a Safari build C4S would benefit from an LSD.
To the other point, of course the system prevents kicking the tail out, that is the whole point of the C4S AWD. It may be more fun, but I've never heard that kicking the tail out is faster than applying power to all 4 wheels. After all, Porsche put AWD on every 996 Turbo, because it is more stable and faster.
I’m getting a gt3 club installed in my 99 c2 next week and I can’t wait. In my research I came across many glowing reviews for rwd cars but didn’t see many reviews for c4s. That being said, do a google search, read through the results and you will be sold.
I highly recommend a wavetrac over a guard unless you get the guard unit for a very good price. Wavetrac is much more affordable and has all the positives of a clutch style and torsen style lsd with the downsides of neither. Only thing is recomend a guard for over a wavetrac is if it a 100% road course car
