Raceworks coilovers?
#61
Got the passenger front on. Same procedure as the drivers. Had to disconnect one of the brake sensor connections to the point held with the 10mm, not hard tho.
There's plus (left) and minus (right) symbols on the rebound adjustment. Anyone know which way is soft? They come fully turned to the plus side. I turned them 5 clicks to the right.
Can definitely feel the spring rate increase over stock. Feels great on regular and mildly bumpy pavement and makes you want to really slow down for any big bumps.
I had a shimmy going over bumps since my RF shock blew. It is no more.
Corners are way more fun. With blown fronts I was always second guessing the car and wondering if I would understeer or not. I still get some understeer but the feedback is much more consistent making it predictable.
This is all just a 30min drive impression and only with the fronts swapped.
#62
#63
At max setting I'm only down 1/4in. Plus the higher rate should reduce the compression distance under normal conditions. So if you're not rubbing with a stock setup then I'd guess it'll be ok.
Take a pic of the gap measurement like I did for comparison.
#65
Figured out the plus and minus. There are 32 clicks. Turned it all the way minus (clockwise) and it was very under damped. Feels worse than a blown stock suspension. Likely because of the higher spring rates. Turned it back up to mid (16 clicks) and feels pretty normal. I think a bit firmer will suit me well.
#66
Good to hear! I'm glad you got the fronts installed and thank you for your initial driving impressions!
I'd be interested to see pictures of your ride height and where your coilovers are set to.
I removed my front and rear struts/springs. I'm ready for the coilovers to arrive and get installed.
Mike
Mike
#68
Here's a pic of the ride height in the front. I have them set at max height.
Also, found another issue while poking around waiting for my new top plates. One of the rears is missing a bump stop. Getting a little concerned about their Taiwan manufacturers QC processes.
I don't track, but would love to do a corner balance just to see if I feel the impact. Might rig something up later this year to DIY if I'm feeling bored.
#69
One too many issues if you ask me. I hope this all works out for you.
#70
That's definitely concerning regarding the bump stop...not something I wanted to hear.
Me too, lol
Mike
#71
I would normally tend to agree, but neither of this issues are highlighting a big quality concern. They're both mix ups that can be easily remedied. And Raceworks has been very responsive on both - like <2hr response time any time of the day.
Fronts ride great with just an initial setup and the build quality is definitely high. Time will tell on the robustness, but a 3 year warranty makes me think Raceworks is willing to stand behind these. Most others in this price range are just 1 year.
For me personally, I just wanted to get something on to replace the worn out stock suspension. Even just stock shock replacements was getting close or exceeding the price of these and that's reusing the springs/bumps/top plates. With these being rebuildable, I don't plan on having to get a new suspension setup for a very very long time.
Yeah I'm at max. They say up to a 1.5in drop which would pretty much eliminate any gap as I show in my measurements above. I might take it down a touch, but I have no interest in a slammed ride.
They're tossing the bump stop in with the correct top plates, so no extra delay. Will update as soon as I get them.
#72
Hopefully this is a isolated case. However I do agree that their customer service has been good. I asked them about an issue with clearance due to my rear tire size, and they offered a potential solution for me if I have any issues.
#73
If all goes well with everyone else, I hope to get a set this summer. I'm feeling the rear getting worse...
#74
Good luck with these!
When you get frustrated, can't go wrong with Bilstein...
#75
